APTuning December Special- Winterize Your Ride For $59.95!!!
<IMG SRC="http://www.aptuning.com/images/custom/logo.png" BORDER="0"><IMG SRC="http://www.aptuning.com/images/custom/banner_rt.png" BORDER="0">
There is nothing worse then having a problem in the winter, with low temperatures and possible snow & ice it can make even minor car troubles unbearable and unsafe. So let APTuning give your vehicle a thorough check and get it ready for the upcoming cold months. Winterize Service includes the following: *Check, flush and fill washer fluid with sub-zero mix. *Check and adjust wiper blades and arms. *Rotate tires or install snow set if applicable. *Properly inflate all tires to spec. *Check charging system and battery. *Check and clean battery terminals. *Check coolant level and condition. *Check oil level and condition. *Check and lube key locks and cylinders. *Check and lube all hinges. *Check heater and defroster systems. *Check and clean door seals. *Check all mechanical and hydraulic brake components. *Check all suspension components. *Check lights for function and light output. *VCDS(Vag-Com) scan of all modules for faults. |
