Go Back  AudiWorld Forums > Community Discussion > Photography Discussion
Reload this Page >
Anybody have a good article the explains how Canon's wireless flashes work?
Old 02-17-2009, 10:08 AM
RKA
AudiWorld Uber User
Default Anybody have a good article the explains how Canon's wireless flashes work?
I was messing around with a trio of 580's over the weekend, trying to get comfortable using multiple flashes. I found one of the two off camera flashes would be delayed when I took a picture. The flash which was delayed seemed inconsistent (sometimes it was #1, other times #2). The manual has limited knowledge buried in it.
I thought they used infared to communicate, meaning you need line of site, but the delay didn't always seem to correspond to what I might have expected given the layout of the room and flashes, and their orientation relative to the master unit. I just feel like I'm missing something the manual isn't telling me.
Oh, what I learned after an hour of playing: Multiple off camera flashes just mean there are more bad ways for me to take a photograph! Heh.
RKA is offline
Old 02-17-2009, 10:09 AM
Default I've only played with 1 off camera 580 triggered by 1 on camera 580..so im no help.
....but i'm also interested in this...so i'm tracking the thread.
Togglehead is offline
Old 02-17-2009, 10:16 AM
RKA
AudiWorld Uber User
Default Can you buy one more and get back to me?
:-P
I need to do more reading on strobist. My initial results were terrible! Shadows everywhere! Flashes seemingly firing in wierd ways that I wouldn't have expected. I don't know.
RKA is offline
Old 02-17-2009, 10:18 AM
RKA
AudiWorld Uber User
So what did you do? Give up and go manual with radio triggers or give up altogether?
RKA is offline
Old 02-17-2009, 10:22 AM
AudiWorld Expert
Default I simply do not understand why people undertake strobe photography before
graduating from a hot light setup. Yeah, it's cooler, but more complicated to control the strobe without really knowing how to manage light from multiple sources.
Specially flash heads that have different characteristics than a real setup.
Oh, and I don't know anything about the CCS (Canon communication system) ;-P
I figure that the day will never come when I sink an additional 4 bills into a flash and simply go to a real strobe system + pocketwizards.
jyoteen is offline
Old 02-17-2009, 10:33 AM
Default Id need to buy 3. The other 2 were lent to me by a friend for a few weeks.
Only got the 430ex now..in anticipation for the 580 master....eventually.
Old 02-17-2009, 10:39 AM
Maestro
Default Canon flashes communicate with each other not by infrared but through pre-flashes
It's the ST-e2 that communicates via infrared.
I don't know of an article on this, but it should be fairly straight forward.
Make sure that all the flashes are controlled by the master (you don't set anything on the slaves themselves, other than setting them to slave mode, assigning the channel and a/b/c designation.
Power ratio etc are all set on the master. Assigning ratio can get tricky (figuring out which is which), but otherwise no rocket science.
You won't see the final settings on the slave flashes until you fire the main flash - then it will transmit the settings to the slaves.
No idea what could cause the delay you are describing, sorry
MichaelTM is offline
Old 02-17-2009, 10:58 AM
TristanP's Avatar
Default No idea - I much prefer the radio controlled method
Cactus, Cybersync, Radio Popper, PW, whatever. Sure, you give up ETTL, but you have FULL control over your setup. Even better is to use them with real strobes.
I'll either use my 430 on camera only, or my Sunpaks off camera only - I rarely mix them. I could use the 430 to trigger the Sunpaks via optical slaves, but I don't want the output from the 430 interfering.
TristanP is offline
Old 02-17-2009, 11:35 AM
TristanP's Avatar
Cool
TristanP is offline
RKA
AudiWorld Uber User
Default Well, I got them set up fine...
they were working, and in a few cases, I got the results I was expecting, but other times I didn't. If they only use preflashes to communicate, then I'm thoroughly confused by what I saw. Considering I was indoors at night and didn't have anything other than ambient incandescent lighting to interfere, there shouldn't have been any delays.
RKA is offline
Quick Reply: Anybody have a good article the explains how Canon's wireless flashes work?
