Inexpensive tripod
Old 02-23-2009, 12:18 PM
Default Inexpensive tripod
Hey, looking for a inexpensive tripod for my Olympus dslr. Just need recommendation. Thanks
vtracer20 is offline
Old 02-23-2009, 12:40 PM
RKA
AudiWorld Uber User
Default Inexpensive is a relative term.
Under $100 is junk. Differentiating between good junk and bad junk is a pointless exercise.
Around $200 you start to get into items that are worthwhile. Of course it also depends on how much weight you expect to put on it. Manfrotto typically offers some good stuff. My rule of thumb is to shop 2x's the amount of weight I'm really going to put on it. Both the tripod legs and the head will have weight capacities to guide you.
RKA is offline
Old 02-23-2009, 12:41 PM
Member
Default what is 'inexpensive' to you?
and why does it need to be inexpensive?
but if you are going that route, i would strongly recommend Amvona/Dynatran. you can find them on ebay. i have a carbon fibre model of theirs with a ballhead. lightweight, stable, and easy to use.
<a href="http://cgi.ebay.com/Dynatran-Pro-PHOTO-CAMERA-TRIPOD-BASE-LEGS-AT-L101T_W0QQitemZ270338169616QQcmdZViewItemQQptZTrip ods_Monopods?hash=item270338169616&_trksid=p3286.c 0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39% 3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50">b ase</a>
they have various types of heads that run about $40-150. for the price, it's hard to beat.
mdwsta4™uroslut is offline
Default My recommendation is not to cheap out. In the long run inexpensive becomes expensive.
Trust me.
noeltykay is offline
Old 02-23-2009, 12:48 PM
Default I disagree with the Amvona...
I have have the carbon fiber model with ballhead, and what started out as a good tripod over time turned into crap. It does not stand the test of time/wear and tear.
Old 02-23-2009, 01:03 PM
Default The sub 20 dollar range is priceless
<ul><li><a href="http://www.amazon.com/Digital-Concepts-TR-60N-Camera-Carrying/dp/B000093UDQ/ref=dp_cp_ob_p_title_0">http://www.amazon.com/Digital-Concepts-TR-60N-Camera-Carrying/dp/B000093UDQ/ref=dp_cp_ob_p_title_0</a</li></ul>
Schumiusedtowin is offline
Old 02-23-2009, 01:17 PM
RKA
AudiWorld Uber User
Default Well, if you put a 15 lb sandbag on the center column, pointed the camera dead ahead,
and shot wide enough that you could crop to fix the creep, I think you might have a solution there!
RKA is offline
Old 02-23-2009, 01:39 PM
Default Did you guys break up or something?
cj99si is offline
Old 02-23-2009, 04:37 PM
Member
Default meh. mine hasn't gotten to that point yet.
although there is some sand grains in the columns from using it on the beach.
Old 02-23-2009, 04:54 PM
Default Re: Inexpensive tripod
under $100 is inexpensive for me
Quick Reply: Inexpensive tripod
