Tires deflate at the same time
I don't know if it a coincidence or what, but every time my tires deflate, all 4 of them deflate and around the same amount of pressure is lost. My tires are usually inflated to 45 psi. Whenever the low pressure light comes in, it's always for all 4 of them, and pressure is usually around 35 psi.
It was a month ago that I last inflated the tires. I'm not sure if this is normal or not, but I'm more surprised that all 4 tires list the same amount of pressure at the same time. And every time when the light come on, it's always all 4 tires.
Tire pressures
As for tire psi going down on all 4 tires. Sounds like ambient temp change . An up or down change of ambient temp of every 10 degrees will raise or lower tire psi 1lb. Example: A drop of 30 degrees in temp will lower each of your tires 3 psi .Sames goes for hot or cold tires. ALWAYS take tire pressure readings when tires are cold. Also set TPM when tires are cold.
45 psi on the door jamb sticker is the tire pressure when the car is fully loaded. For up to 3 passengers, the Owners Manual specifies a tire pressure of 32 psi all around (for 17- and 18-inch wheels) and 33 psi all around (for 19-inch wheels).
For a full load:
17" and 18" wheels: 33 Front / 36 rear
19" wheels: 44 front / 46 rear
For a full load:
For a full load:
For a full load:
kirupa
A4 (B8 Platform) Discussion
05-24-2010 08:53 PM
bzcat
15
12-07-2006 02:29 PM
CBJ
03-26-2002 04:31 PM
