19in OEM wheels on SQ5: fitment question
I'm not sure if this question has already been answered. I'm about to get these OEM 19-in wheels (standard on newer 3.0T) and I'm wondering if they will fit and clear the brake calipers on the SQ5.
Same wheels as in this post:
https://www.audiworld.com/forums/par...tires-2885031/
This is for my winter setup (235/55/19). According to my preliminary calculations, I should be OK.
Can someone confirm? Thanks.
I run the same wheels for the winter as the OP. You will need a 5mm spacer. I went with 10mm spacers since they have a factory lip profile for being hubcentric. No issues. Bought the spacers from ECS with bolts as well. You actually only need spacers in the front. The offset of the wheels is not so much of a issue, the spoke design puts the spokes within a 1mm of the caliper.
nobbyv
S6 (C7 Platform) Discussion
76
11-20-2016 08:41 PM
willgotthardt
11-09-2008 10:38 AM
