View Poll Results: Does your Q5 exhibit abrupt shift from 1st to 2nd gear when you first start driving?
I have a Q5 3.0T and I HAVE this issue
15
16.67%
I have a Q5 3.0TDI and I HAVE this issue
13
14.44%
I have a Q5 2.0T and I HAVE this issue
21
23.33%
I have an SQ5 and I HAVE this issue
13
14.44%
I have a Q5 3.0T and I DO NOT have this issue
10
11.11%
I have a Q5 3.0TDI and I DO NOT have this issue
8.89%
I have a Q5 2.0T and I DO NOT have this issue
7.78%
I have an SQ5 and I DO NOT have this issue
5.56%
Multiple Choice Poll. Voters: 90. You may not vote on this poll
Abrupt shift from 1st to 2nd gear on a cold engine?
AudiWorld Expert
I've posted about this before, but I thought I'd try to poll the owners this time to see just how common this is. And if it is not common, I guess I need to have my service dept take a look at it. The problem is, the engine needs to be completely cold - not driven for many hours or overnight.
When I first start driving (again, on a completely cold engine/trans), regardless if summer of winter, the trans seems to hold onto that 1st gear unusually long, and then somewhat violently (or should we say, abruptly) dumps it into 2nd gear. It only does it this one time. All the subsequent shifts are smooth. I could come to a stop in 5 seconds and then start moving again, and that next 1st --> 2nd shift will now be smooth.
None of the other automatic trans I've ever driven did anything like it, but my experience with automatics is rather limited in general, so I don't want to use this as a benchmark.
Please respond to the poll above. Feel free to chime in with any add'l detail as well if you were able to do something in order to fix it.
Thanks!
Thanks!
My 2012 2.0T does this every time I pull out of the driveway in the morning and drive to work, then again when I pull out of the parking lot at work to come home. It happens during the first shift the transmission makes moving forward and never again until everything cools down completely. I have noticed if I accelerate hard (as hard as the 2.0T can accelerate) it doesn't lurch, but there are times you can't or don't want to do that.
My 2015 3.0 TFSI does not have the problem.
I wonder if the year model might make a difference.
The service department has "taken a look at it" but can't find anything.
AudiWorld Expert
I've heard some people having some luck installing the aftermarket transmission mount. I have one sitting here, just didn't have the opportunity to install it yet...
My SQ5 does this exactly. Other VAG vehicles that I've had with autos also did this: 2008 Rabbit, 2009 Tiguan. This is my first Audi. Transmission mount insert improved some areas but did not noticeably change this behavior for me. I just live with it as a normal operating quirk.
I feel as if this is normal. The engine is cold, the transmission is cold, the fluids are cold. Once they warm up it doesn't do this. The engine holds gears longer to help warm up and first gear is tall so a slower shift due to the coldness will make it feel abrupt.
AudiWorld Expert
Possibly the trans just needs some movement of the parts to get the fluid circulated.
Interesting results so far, without any apparent pattern. About half the people are reporting the issue, and it is not specific to any engine.
AudiWorld Expert
Does anyone know if Audi issued any TSBs re: updated trans programming?
Not saying this is necessarily a programming issue, but having the latest software version should probably be the starting point of any troubleshooting here.
AudiWorld Expert
Thanks for the responses so far. Here is a quick summary:
Approx half of all the responders indicated they have noticed this issue. Most of the 3.0T owners did not notice this issue. Most of the 2.0T owners did notice this issue. The 3.0TDI and SQ5 were about half and half.
I did hear that on other models that use this ZF trans and had this issue, replacing valve body helped make this issue go away. I will bring it up to the service advisor next time, but I'm kind of expecting him to say "They all do it," which is only about half true based on the results of this unscientific poll.
Code:
... Have Issue No Issue 3.0T 22% 78% 3.0TDI 50% 50% 2.0T 86% 14% SQ5 56% 44% Overall 51% 49%
Mine does it, also takes a bit to shift into drive on a cold start, as in move the shifter and wait a second for it to physically shift the transmission into drive.
