APR ECU Stage I tune, stiff steering?
Just some bum.
We recently had our 2014 Q5 2.0 TFSI flashed with APR's ECU tuning. The steering has been much stiffer (resists turning) seemingly randomly.
Is this a feature? I had read up on these tunings for a good couple of years waiting for the car to be off warranty before getting the flash.
Other than the steering, this ECU update has been amazing!
Normally you can select the comfort or auto steering if this was changed to dynamic with vcds coding or retrofit ADS where you can change comfort auto dynamic and custom.
FWIW if steering is randomly stiff it might be an issue with power steering. I believe there was a TSB. I know on my '14 SQ5 there was, not sure if it also affects 2.0T.
ECU tune should not affect steering at all unless like apoelistas said it was changed to Dynamic ADS, but then it would just be stiff all the time.
A vcds scan would give as the info to check if there is a firmware update.
I would think that letters were sent to all affected Q5 owners for the steering CU firmware update unless the firmware update if done (recall) did not complete successfully.
This recall was for the SQ5.
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/...rchResult&pg=0
Just some bum.
Thanks everyone. Unfortunately our Q5 doesn't have the drive select option (we have the Technik package iirc which doesn't include it. Nice moon roof and HK sound system) Thinking it may be enabled after the update, I looked in the Car settings of the MMI and saw nothing new regarding drive settings before posting. This is a Q5, not an SQ5, so I believe that recall doesn't affect us. We are diligent about all recall notices.
I noticed it when I started driving right out of the parking lot but thought to check the MMI later, not when driving. And the better half hates it. In any case, we're hoping it's a known, undoable side effect of the ECU flash. Things that mess with steering are more than a bit concerning... I have written the installer and APR, but it seems they're both closed over the weekend.
Thanks again, everyone! Will update the thread as I hear more.
Just some bum.
I've only had it since Friday and other than the steering issue, it's been a blast! The better half hates the random stiff steering, so I'm crossing my fingers that it's something they can undo or change.
Acceleration even at highway speeds is fast.
91 octane, any higher is not at every station (not even close) around here.
Just some bum.
Update: I took the Q5 into the local APR dealer this morning. The owner was there this time and took it for a spin with me. He noticed the random 'stiff spots' as well, especially at low speed (e.g.: parking lots) where you'd sometimes need to firmly grip the wheel to turn it.
They took out the flash so the car was back to factory. It was exactly as it was three weeks ago: finger-touch steering, no stiff spots. They reflashed it again and everything worked perfectly: a noticeable boost from the APR tuning and the steering was seemingly untouched. I'm not sure if APR has an updated flash they put in, but it seems to be fine.
Odd thing that's been gnawing at me since it was fixed earlier this morning: everyone was telling me the tuning should not affect the steering, but the steering was messed up right after the flash and it reverted back to normal right after the flash was removed. So there must be something touching steering somehow. If it were an unrelated glitch with the steering that coincidentally arose right after the flash, it should still be there, right?
