Audi Q5 2009-2012 B8 Retrofit Road Map and VCDs CM list
Retrofit RoadMap / 2009 Q5 purchased December 2016
Audi Q5 Spec from factory
VCDS Scan
This list could be helpful to other retrofitters/enthusiasts because all of my modules were updated to latest firmware (or replaced).
- TFSi 211bhp
- S-tronic 7 speed
- 19” wheels
- Hill Hold
- Hill Descent
- Home Link
- EPB (Electronic Parking Brake) coded to remove brake pedal press.
- ESP/ABS/EDL
- Power Windows controlled by Key Open/Close
- Folding Side Mirrors
- Automatic Rain Wiper Sensor Dimmable Mirror
- Deflation Warning System(TPMS) was disabled but was enabled (coded) due to supported hardware
- 4 Front 4 Rear Parking Sensors with Graphical Support
- Radio Concert with rear AUX in
- Servotronic Steering 1N3
- 4 Spoke Multifunction Steering Wheel with Cruise Control
- Quattro / Torsen Center / Open Rear Differential with EDL
- Bi-Xenon headlights + DRLs + Led Rear
- Fog lights
- Full Leather trim
- Full Sport silver trim
- Comfort turn signal 3 blinks activated
- Motorway Lights activated
- Efficiency setting activated
- Battery meter activated
- Audi Drive Select
3 Spoke Steering Wheel with DSG Paddle Shifts + airbag (Multifunction + Cruise Control)RS-1103 Back Up Camera (not OEM)(see post 3)Kufatec/Fiscon Bluetooth Basic Plus Integrated Hands Free Telephone (coded)(see post 3)A2DP module connected to AUX(see post 3)- Trailer Hitch with 13 Pole support + electrical CM (coded same as original). + rear bracket for CU
- Upgraded Intercooler (From Q5 3.0 diesel)
- Racechip with bluetooth
- 4 Door Warning and Puddle lights
- Internal Led kit
- Keyless Start button Keyless Entry Audi Advanced Key (had to change key and comfort module to an advanced one)
- Boost Tap and digital gauge
- Air Quality Sensor and 3 Zone HVAC replacing 1 Zone HVAC (not full 3 zone retrofit)
- Full Alarm including Driver Door Switch for Tilt and Alarm Control Switch On/Off.
- OEM Red Ignition Coils (from SQ5)
- Tailgate Spring Struts, automatic Key Opening
- Driver Switch for opening Rear Tailgate
- OEM led kit for license plate (as per newer Manufacturing Years)
- External Retrofits 2 S-line badges, fog light garnish, side silver strips from Landrover, S/S tailpipes
- OEM Q5 roof cross bars.
- High Beam Assist (had to upgrade the Gateway Control Module to one with Extended Can)
- Revised Pedal Part Number from later MY with better response, 8k1723523A.
- Center Armrest tray, and 3 door containers (bcs RHD driver door container not available, had to buy 2 rear pairs)
- Upgraded to latest CM the following parts: EPB (electronic parking brake), Home Link CM, Light Switch Control Module.
- Other hardware failures were fixed by previous owner, including Oil Consumption Stage 2, Oil Consumption Stage 1 (I did because audi did not perform stage 1), Led control Module, Transmission ECU, diverter valve, and Another Part on engine which I cannot remember at the moment.
- HPFP Pipeline had almost melted so I had to swap the part to a revised one. Yes Audi Dealer Refused to do this for free.
- Lap Timer/Temperature activated and Efficiency activated on Instrument Cluster (after firmware update of Gateway, Instrument Cluster, and Electronic 09 control module)
- Radio Concert with Dab + support from facelift. Antenna was also retrofitted to the rear side left glass panel.
- ANDROID touchscreen 7" 1024x600 multimedia display inclusing 2 usb connectors.
- 4 spoke paddle shift Multifunction steering wheel from B8.5 facelift Q5 + Airbag Retrofit
- Intake Manifold upgraded solenoid valve and connecting hose upgrade (ΤPI) 2044003/1.
06H906283B Solenoid valve
06H133583F Connecting hose - Front passenger footwell ambient mmi controlled light
- Lock Unlock internal Door Buttons for front passenger side and rear doors
- Wing Side Mirror ambient Led Lights.
- Exterior Handle Leds ?? (might not work)
- Full HVAC 3 Zone Retrofit will first add rear passenger line and see how this behaves (not in a hurry). 30%
- Passenger airbag disable switch 70%. Remaining 3 wires from A pillar to center console srs airbag control unit connector
VCDS Scan
Q5 VCDs list with all my revised Control Units. Either Hardware or Firmware wise most control units were updated/upgraded to latest, with exception Airbag Control Unit. This list is only for research purposes and only given out for the purpose of comparing yours with a benchmark, like best in class . Note I am just a Q5 owner, an enthusiast and self trained, not affiliated in other respect with Audi. Lots of research was performed (ERWIN, forums, electrical diagrams, comparing VCDs CU lists, flashdaten, etc, including taking risks). (My dealer debated that my Q5 was not sold by them. Due to the retrofits, firmware updates, and hardware updates I have done to it they thought it is was imported from UK.) Note this is S-tronic and RHD TFSi 2.0l and 2009 Q5 but has better firmware than latest prefacelift Q5. Marked the first firmware in bold in order to explain what is crucial to compare. Trailer and Telephone control units are aftermarket. Control units 01 for FW update, and 046 comfort unit swap with key programming I have visited the dealer. As for the rest the work was carried out by me. 08, 19 and 56 CU swap I needed CP removal. Not sure how much I spent in total, but it seems a lot because apart from the hardware I have purchased also, battery charger, VCDS original, VCP original vas5054a original in order to perform the updates and retrofits.
Firmware updated: 01,02, 08, 09, 10, 17, 19, 56
Part Upgraded: 08, 09 switch, 016 angle sensor, 019 CU, 019 battery terminal, 020, 046 CU, 046 Homelink, 046 Alarm Sensor CU. 046 Siren, 053, 056 radio concert, 069, 077 + steering wheel was changed to tiptronic/dsg/paddle shift and since it was 3 spoke, SW airbag was upgraded to latest firmware PN too because mine was not compatible with 3 spoke.
Some have both upgrade and update.
Here is my VCDs List
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 R HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0002
Coding: 0121000C240F0960
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 AB HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H04 0011
Coding: 000001
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 C HW: 8R0 907 379 C
Component: ESP8 quattro H06 0230
Coding: 02DD00
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CQ HW: 8K0 907 064 CQ
Component: BCM2 2.0 H07 0437
Coding: 051500
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0182
Coding: 64050000
Coding: 64150000 (visual presentation Radio concert facelift)
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 H HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0410
Coding: 260090910074AF210701000000001D0D009D67080201016100 0000
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 090112 H10 0041
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 0B4D25
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 8K0 907 410 HW: 8K0 907 410
Component: EHL205.06.02K H02 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0082
Coding: 110105
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 B HW: 8R0 959 655 B
Component: AirbagVW-AU10 H03 0310
Coding: 30353131313030303030554A305238523053
Crash sensor for side airbag: driver side:
Crash sensor for side airbag: front passenger side:
Crash sensor for side airbag: rear: driver side:
Crash sensor for side airbag: rear: passenger side:
Crash sensor for front airbag: driver side:
Crash sensor for front airbag: front passenger side:
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Coding: 000037
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 900 HW: 8R0 920 900
Component: KOMBIINSTR. H08 0258
Coding: 2F9E220003000008810800
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 AG HW: 8T0 907 468 J
Component: GW-BEM 6CAN H06 0120
Coding: 00C303
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Coding: 02022064747464545425363E
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Coding: 011412205001440004
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Coding: 015F0E2020B944830530050020000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Subsystem 2 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000006
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H01 0350
Coding: 0500048204000D02417F8F0003
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Upgraded to dab radio concert facelift
Part No SW: 8R2 035 186 G HW: 8R2 035 186 G
Component: Concert3 DAB H05 0480
(Changed later to
Coding: 0500048004068D02417F870003)
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Coding: 010412204001240004
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: Anhaenger H09 0100
Coding: 0100000000000000
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 31P HW: KTC 364 31P
Component: SWP:3.31.6 H24 0220
(Address 77 was erased after installing android)
Coding: 000001
Coding: 02DD00
Coding: 051500
Coding: 64050000
Coding: 01DD13
Coding: 0B4D25
Coding: 110105
Coding: 000037
Coding: 00C303
Coding: 0000006
Component: Display
(Changed later to
Component: Display
Since my 7" android multimedia touchscreen upgrade, I have removed the kufatec telephone handsfree kit (address 77), and the back up camera control unit (which is not shown on the scan), thus the list above has changed. will try to post a new one for comparison reasons. Also I did not undertake a radio concert facelift firmware update yet because it takes more than 2hrs 30 mins (it is 2 firmwares older) and I have to find time. Also A2DP/AUX has been removed from my car. (3 technologies removed, 1 installed).
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Coding: 000001
Coding: 02DD00
Coding: 051500
Coding: 64150000
Coding: 01DD13
Coding: 0A4D25
Coding: 110105
Coding: 000037
Coding: 00C303
Coding: 0000006
Coding: 0500048004000D02417F0F0003
Component: Display
Coding: 000001
Coding: 02DD00
Coding: 051500
Coding: 64150000
Coding: 01DD13
Coding: 0A4D25
Coding: 110105
Coding: 000037
Coding: 00C303
Coding: 0000006
Component: Display
Thanks. This year I have enjoyed most of the retrofits. Totally worth the time, money spent and effort exerted.
iamaudi.com
A4 (B8 Platform) Discussion
14
01-27-2009 11:46 AM
