Audi Q5 - DataBase - Useful Information
Hello!
Since I bought my Audi Q5 I search on web for all relevant information about this model.
I have already found some interesting stuff, so I think is good idea to share that with all members.
If anyone have more files, can send me a pm or mail and I will add that to this topic.
Tech Docs:
Self-Study Programme 429 Audi Q5 Aggregate (DE)
Self-Study Programme 433 Audi Q5 (ENG)
Self-Study Programme 434 Audi Headlight Assist System (DE)
Self-Study Programme 434 Audi Headlight Assist System (ENG)
Self-Study Programme 435 Audi MMI 3º Generation (DE)
Manuals:
Quick Manual - 2008 (DE)
Quick Manual - 2012 (DE)
Catalogues:
2009 Audi Q5 (ENG)
2010 Audi Q5 (ENG)
2012 Audi Q5 (ENG)
Audi Q5 Accessories - 2009 (ENG)
Audi Codes Decoder:
Using link above, you can know all the equipment that came with your Q5.
Just copy all the codes that you have in the label inside of your maintenance book.
http://igorweb.org/e...ec/default.aspx
Tech Docs:
Manuals:
Catalogues:
2009 Audi Q5 (ENG)
2010 Audi Q5 (ENG)
2012 Audi Q5 (ENG)
Audi Codes Decoder:
Audi Codes Decoder explained
The example of my car:
I past all the codes:
e0a; 7d5; 4ue; 6xe; 5sl; 5ru; 1kw; j0z; 1la; 1at; 1ba; 3fa; 5mf; 7x4; f0a; 8gu; 0g1; 0Yd; 0je; th3; 5ka; 8bp; u1a; x3g; 1n3; 2zq; 8q3; 9q4; 8z4; d93; 7t6; cs7; 7k6; 4x3; vj1; 3l5; 4kc; 3y0; 4k4; 5d7; 1sa; 7gg; q1d; 4gf; n3q;
And I got this info:
E0A = No special edition
7D5 = DVD player
4UE = Air bag for driver and front seat passenger
6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated
5SL = Left exterior mirror: aspherical
5RU = Right exterior mirror: convex (large viewing field)
1KW = Disc brakes, rear
J0Z = Battery 520 A (110 Ah)
1LA = Disc brakes, front
1AT = Electronic stabilization program (ESP)
1BA = Standard suspension/shock absorption
3FA = Without roof insert (standard roof)
5MF = Decorative aluminum inserts
7X4 = Park distance control, front and rear
F0A = No special purpose vehicle, standard equipment
8GU = Alternator 140 A
0G1 = Gearshift lever
0YD = Weight range 4 installation control only, no requirement forecast
0JE = Weight category front axle weight range 5
TH3 = 4-cylinder diesel engine 2.0 L unit 03L.B
5KA = Three rear seats
8BP = Bi-functional headlight with gas discharge lamp
U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
X3G = National sales program Portugal
1N3 = Speed-related variable steering assist (Servotronic)
2ZQ = Leather trimmed multi-function steering wheel for air bag system
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q4 = Multi-function display/on-board computerwith check control
8Z4 = Moderate hot country
D93 = 4-cyl. turbo dies. eng. 2.0 l/125 kW 4V TDI common rail Base engine is TG3/TH3/TL4/TM4/TP4/TU3
7T6 = Navigation system (MID)
CS7 = Alloy wheels 8J x 19
7K6 = Flat tire indicator
4X3 = Side air bag front with curtain air bag
VJ1 = Reinforced bumpers
3L5 = Electric seat adjustment for both front seats
4KC = Side and rear windows in heat-insulatingglass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D7 = Carrier frequency 868 MHz without panic button
1SA = Without additional front underbody guard
7GG = Emission standard EU4 DPF
Q1D = Sports front seats
4GF = Windshield in heat-insulating glass
N3Q = Fine napa leather seat covering
7D5 = DVD player
For comparison, this is my Canadian 2.0T:
7D5 = DVD player
4UB = Air bag for NAR
6XL = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
5SG = Left exterior mirror: flat
5RW = Right exterior mirror: convex (US) large viewing field
2EK = Disc brakes, rear
J0B = 520 A (92 Ah) battery
1LB = Disc brakes, front
1BL = Suspension/shock absorption (closed-loop)
3FU = Big roof system
5TG = Decorative aluminum inserts, dulling
7X8 = Park distance control, front and rear with rear view camera
9G3 = Alternator 120-180 A
0G7 = Tiptronic
0YE = Weight range 5 installation control only, no requirement forecast
TL6 = 4-cylinder gasoline engine 2.0 l unit 06H.H
8EH = Bi-functional headlight with gas discharge lamp, for driving on the right(US design)
QZ7 = Power steering
2PK = Leather trimmed multi-function sports steering wheel w/ Tiptronic
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
9Q8 = Multi-function display/on-board computer
D2D = 4-cyl. gasoline engine 2.0 l/155 kW 16V turbo FSI, homogeneous; base engine: TM2/TV2/TG6/TJ6/TD6/TP6/TL5/TL6
C7D = Alloy wheels 8J x 19
7K0 = Without tire pressure warning light
2K8 = Reinforced bumpers
3L4 = Electric seat adjustment for both front seats, drivers seat with memory system
4KF = Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
4I3 = Central locking system "Keyless Entry" without deadlock
5D2 = Carrier frequency 315 MHz
1SH = Additional engine and transmission guard
7GB = Emission standard ULEV 2
4GQ = Windshield in heat-insulating glass
7D5 = DVD player
0G7 = Tiptronic
Hello!
I am looking for Q5 2013 owner's manual
I was just wondering about that Headlight Assist System. Is this something that we can turn on in the U.S. using Vagcom? What's the story. Is it only available with the adaptive headlights? Is it even available at all in the U.S.? There is no mention of it in the 2012 owners manual at all. Anyone know. Thanks.
https://www.audiworld.com/forums/sho....php?t=2837714
I don't think Headlight Assist was ever an option here that I've seen, which is disappointing because I'd rather like to have it.
Headlight Assist appears to require an special camera in the rearview mirror assembly. I doubt that vehicles without Headlight Assist have that camera, so adding it would be more than just a VAG-COM setting, sadly.
Adaptive light
Illuminating around the bend: adaptive light helps you to see further and see earlier in poor light conditions and especially in bends. The dynamic cornering light swivels the headlights in the direction of travel, following the degree of turn of the steering wheel. It thus effectively illuminates the path of the road ahead.
Innovative even after dark: adaptive light is well ahead of conventional headlights. During cornering, the road ahead and any obstacles just around the bend used to be hidden in darkness for some time with headlights only capable of illuminating a straight section of road. Audi adaptive light, however, dynamically adjusts to the movements of the steering wheel and the changes in the vehicle’s heading: it calculates the necessary alteration of the headlight position from various parameters, such as the road speed, steering angle and yaw rate. At speeds between approx. 10 km/h and 110 km/h, the headlight module swivels by up to 15°, following the degree of turn of the steering wheel. The advantage: considerably better illumination of the road ahead when turning and cornering, plus improved safety because the driver can see obstacles and other road-users early, and has time to react with due caution. The dynamic cornering light system Audi adaptive light is only available in conjunction with Xenon plus.
