Audi Q5 Digital Boost Gauge
#11
This is the fault code that I get from VCDs. The specified boost pressure is not reached. To me the car drives well, no boost leak noise. any ideas???
5671 - Boost Pressure Regulation
P0299 00 [104] - Control Range Not Reached
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 123167 km
Date: 2019.01.03
Time: 00:11:50
Engine speed: 4208.00 /min
Normed load value: 99.6 %
Vehicle speed: 56 km/h
Coolant temperature: 86 °C
Intake air temperature: 23 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.099 V
Unlearning counter according OBD: 40
Readiness: 0000 0000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 123167 km
Date: 2019.01.03
Time: 00:11:50
#12
I'm pretty sure you already checked this link: 16683/P0299/000665 - Ross-Tech Wiki
Does this happen with and without the boost gauge hose connected?
#13
still same.
Yes I did check ross tech wiki. . It gives some guide. I will discuss below.
1. Not sure if this is caused by my chiptune. "exhaust system is restricted (typically the Catalyst) this fault may be the end result.)." I may hae to disconnect my chiptune now to test this theory.
2. If it is caused by the turbocharger boost controller valve sensor that is difficult to replace.
3. Wastegate play means I need to buy a new turbocharger.
4. DIverter valve I can check
5. For pipeline leak checks I have to buy a smoke machine.
#14
#15
And I hope it's just either the DV or a boost leak from a faulty or badly connected hose, a new turbo would be $$$$!
#16
Yes turbo is expensive. I do hope that it is either DV or a hose.
Do you have information on manifold flap delete, was watching today a video of how to??? is this good or bad???? do you know what are the disadvantages of this?? My manifold flaps make noise when engine is cold. Wondering
First I need to test DTCs with chiptune off. Will be testing this for a week.
#17
I read about flap delete a while back when my I take manifold broke, I first though flaps were just stuck due to carbon buildup but it was the flap actuator that was broken so I replaced the whole unit.
I know that you need to program the ECU if you delete the flaps though, IE sell a metallic intake manifold with no flaps, looks really cool, but it’s pretty expensive: https://www.performancebyie.com/ie-2...ntake-manifold
Regarding DV valve, what part # do you have? I’ve never seen a metallic OEM one.
#18
#19
Blue box is the DV I fitted when I went APR stage 1, you might be right about being painted aluminium 😉
Ready for APR STG I
Ready for APR STG I
#20
Here is mine was not expensive from my dealer. I have this as a spare part since it was working fine when I removed it. Previous owner must have replaced it.
