Audi Q5 vibration at very low speed & at braking
Hello!
I have a problem with my Audi Q5 2009 3.0 S-tronic, mileage 210 000km. When selecting D or R and start moving, I feel vibration. When car is standing, all is good. Also the same is happening when braking and the speed is reaching about 20km/h to zero. At higher speeds there is no problem - switching gears normally and all OK. Problem is only at very low speeds - for example at traffic jam, when accelerating from zero to 5km/h and back to zero, you can feel the vibration. Also the gear change from D1 to D2 seems to be a bit jumpy. When checking the car with VAG, the following error showed up: P157300 - Left engine mount solenoid valve; open circuit. Could it be, that changing the engine mount would solve the problem? I am thinking more, that it is the problem of transmission and I have been advised, that the bigger clutch is worn out. What do you guys think, what may be the issue?
Hello!
Warped brake rotors can cause vibration as well.
Also, inspect for worn universal joint in the driveshaft.
Can't help in regard to DSG transmission.
With these many km's on your vehicle, it could be many items to check.
Hello!
I had a similar issue from about 8 km/hr to 60 km/hr and dealership suspected a stone in the rotor. Drove it for a while longer and it disappeared. I did have vibrations at faster speeds previously 45-110ish and it was found to be both front and rear passenger side bearings were shot.
Fixed? Same issue here with my facelifted TFSI
Hello!
Bad Dave
Audi A3 / S3 / RS 3
11-22-2006 11:08 AM
perkins4236
09-21-2004 11:13 AM
