BF Goodrich KO2s on 2017 Q5
#11
Wheel Offset?
I've been thinking about this exact setup for winter. What was the offset on those 18x8 wheels you mounted? My 20x8.5 are 33mm. Most of the Audi wheels for the Q5 in 8in width are 39mm. Worried that a 39mm offset might rub with a 255 tire.
#12
I have 19" OEM wheels on my 2014 Q5. I am running 255/50-19 tires with no problem.
#13
Got 2 of these in my shop . . . gets everything nicely up out of the way.
https://www.tirerack.com/accessories/detail.jsp?ID=164
#14
Even though winters are mild here (just cold and rainy, no snow or ice) My 2009 Q5 came with 18” 235/60 and it’s perfect for the roads in my country (Uruguay) where we celebrate pothole birthdays. Ride is comfortable and compliant, newer models come with low profIle 19”, 20” and even 21” wheels, you’ll see them going aftermarket for 17” or 18” soon after purchasing the car.
#15
Not sure that answers my question. The OEM 255/50-19 runs on a 19x8.5 wheel with a 33mm offset like my 20s. The original post is running 255/55-18 on an 18x8 wheel without mentioning the offset. If they are OEM they probably have a 39mm offset. In that case the 255 tire will be 0.080in closer inside the wheelwell than a 33mm offset wheel. Just looking for confirmation that a 39mm offset 18x8 wheel will not rub with 255/55-18 K02s.
#16
#17
After mounting and installing this setup, I turned the steering wheel to full stop in both directions and observed no binding or rubbing, so I think it's good. Also, when standing a mounted 235/55-19 stock tire/wheel next to a mounted 255/55-18 KO2/wheel, the extra width of the KO2 is because the edge of the sidewall in the KO2 is more vertical and tapers less toward the tread than the regular all-season tire.
#18
#19
Originally Posted by CompositesGuy
Did you start with the 255s on your Q5? From the site below 2014 with 255 are on 8.5in wide wheels with 33mm. The 235s have 8in wide wheels with 39mm.
https://www.wheel-size.com/size/audi/q5/
#20
It will depend on width. I just have 4 on mine. Also, the wider you extend it, the more it will droop in the middle [one of the short comings]. But, trying to remember as I've had them up for years, I "think" I put the risers on 48" centers [3 16s"] so it was more a function of being able to fit 5 wheels/tires between the 48" centers? Doubtful. Now, there are those grab the backside of the drywall hanger devices but I don't think I'd trust my set of wheels to those. You'd want them solid in studs.
