BF Goodrich KO2s on 2017 Q5
#21
It will depend on width. I just have 4 on mine. Also, the wider you extend it, the more it will droop in the middle [one of the short comings]. But, trying to remember as I've had them up for years, I "think" I put the risers on 48" centers [3 16s"] so it was more a function of being able to fit 5 wheels/tires between the 48" centers? Doubtful. Now, there are those grab the backside of the drywall hanger devices but I don't think I'd trust my set of wheels to those. You'd want them solid in studs.
#22
https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&autoMake =Audi&autoModel=Q5+3.0+TDI&autoYear=2016&autoModCl ar=Prestige&initialPartNumber=W01669202B&i1_Qty=4& wheelMake=O.Z.&wheelModel=Superturismo+GT&wheelFin ish=Black+Painted&wheelFinish=Black+Painted&showRe ar=no&packageFlow=false
#24
There's something fundamentally wrong when I look at these photos. To each his own, sorry.
#25
It would be really interesting is they were on 10"+ wheels with 25mm offset and spacers. It would look very 4x4 truck offroad look. I wouldn't do it, but it would be nice to see someone do it.
#26
The project is complete! I mounted the tires, drove it around the block (got up to about 55), checked for rubbing/clearance issues (there were none at all), then removed them and reinstalled the stock wheels/tires for the rest of the summer. Below are a few pics I shot.
On the road, it seemed to accelerate similarly to before. There's definitely quite a bit more road noise, which I expected. It also feels like there's more drag from the tires - as if the Q5 doesn't want to coast as much as it does with regular tires. Overall I'm happy with the choice. Now I just need to rig up a tire storage solution for my 10 extra tires and wheels. The shed is getting a little cramped!
#27
Ha ha. No 10in wheels for me, but I am thinking about a 15mm/20mm spacer kit to flush the wheels.
#28
For winter's in Idaho, and the back roads around here, these would be perfect.
Nice enough on the highway, but able to handle any dirt/fire road use that I do in the summers. Should have more sipes for really good winter traction. (Easy to solve locally, just have them siped down the middle of the tread pattern, and they will be much better on ice and packed snow.)
Nice thread.
BTW, I have not tried them yet, but have the Conti Snow tires from last season that I used on my 2001 S8 on the stock "wagon cart" wheels, they were AWESOME on snow and ice, but have a much less "aggressive" looking tread design. I've had some excellent results from both the Conti and Blizzak snow tires on my Audi's, they are pretty much unstoppable if you don't try and push through 4' high snow banks, and get high centered.
Nice thread.
#29
Have 2016 Q5 Pre Pls; w/235/60/18. Going to put on Conti LX20 255/55/18. Had the LX20 on previous MB ML. Very good results. Continental will likely have a promo for Labor Day. I feel that the LX20 is a good compromise tire for a heavy SUV. Still a good ride.
#30
Just installed mine. Curious, what pressure are you running with the K02? TireRack sent mine inflated almost to max pressure for max load. 60psi. That was definitely too much for the Q5 GAWR. Handling was definitely squirrely at that pressure. My DWS06 were pressurized to 33psi. Based on my own calculation for the load index for the K02 and Q5 GAWR, the pressure should be about 37psi. I am running
40psi. Handling is quite good at that pressure.
As to the tire pressure, good question; to be honest, I didn't check the pressure before installing them because I only drove it about one mile round trip once I mounted them before I removed them and put the 19" all seasons back on. As I approach 30,000 miles, the all-seasons are nearing the end of their life, and I'll put the KO2s on for the winter and possibly longer sometime this fall. I think I'll probably try 40 psi as well, knowing I'll lose a few pounds of air as the weather gets colder.
