Brake caliper bolt tightening torque?
Old 06-09-2016, 01:36 PM
rez
rez's Avatar
Default Brake caliper bolt tightening torque?
Any of the tech gurus know the tightening torque for the brake caliper and the caliper carrier bolts?
Old 06-09-2016, 05:10 PM
Bob Petruska's Avatar
Front or rear?
Old 06-09-2016, 07:23 PM
rez
rez's Avatar
Originally Posted by Bob Petruska
Front or rear?
planning to do both front and rear, thanks!
Old 06-09-2016, 08:59 PM
spijun's Avatar
Front:
Rear:
Old 06-10-2016, 08:57 AM
rez
rez's Avatar
Thanks spijun! And thanks for the extra detail!
Old 03-25-2020, 12:32 PM
aware's Avatar
Default Brake caliper carrier bracket
Any idea why it says "Always renew if removed" because they don't appear to be TTY bolts
Old 03-25-2020, 12:40 PM
MurrayA4's Avatar
The "always renew" suggestion is likely a liability thing, I'm being kind because I'm sure they don't make any $$ off this stuff - hah ! It's been around for a while amongst all manufacturers.As you stated the exceptions are TTY "stretch bolts" and any hardware components that are visually in need of replacement.
Old 03-25-2020, 12:45 PM
gk1
gk1's Avatar
In my experiences in the case of bolt number 4 they come with locktite pre-installed. As Murray said more than likely a liability thing. I have reused them without issue by re-applying locktite.
Bolt 16 & 17 are obviously TTY and should be replaced.
Old 03-25-2020, 01:13 PM
MurrayA4's Avatar
Yes the "locktite" observation is very valid.Usually blue but sometimes green.It's also always wise to clean out the threaded surfaces with brake cleaner etc.
Old 05-02-2020, 11:08 AM
Diesel68's Avatar
Does anyone here know where if local auto part stores carry the front brake bolts 3 and 4 as well as the rear bolts 4, 16, and 17? Or should I just go to the dealer to get them
Quick Reply: Brake caliper bolt tightening torque?
