Can not find Headlamp Range Control Module
Dear community,
long time reader - now with the first question .....
My Q5 is a 2014 3.0TDI Prestige Plus with (Bi-Xenon) HID headlamps. It is a US model and i am getting ready to modify it as we are planning to take it with us to Germany.
So far i have swapped the taillights to have amber turn signal - re-pinned and reprogrammed. All good
The problem is now with the HID headlights.... i have sourced European headlights with AFS (dynamic and static cornering). Was going to swap the headlamp range control unit to one that supports AFS (J745) but .... i cannot find the original module (J431). As per the wiring diagram it should be located behind the glove box - nothing there. Even more confusing the car is not equipped with the Front left level sensor (G78), it only has the Rear left level sensor installed (G76). (Nothing would suggest it had something installed ever there)
I have swapped the headlights and all the lights are working, obviously the level and cornering functions don't. I have programmed it with VAGCOM to have AFS and it is not accepting the code (well, no control module so that was expected). No dipping at startup either ...
The option sticker suggests that it has option 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
My questions now ....
1. Does anyone have a wiring diagram with this setup (w/o front left level sensor) ??
2. Where is the rear level control sensor connected to?
3. Is there an alternative location for J431?
Any help is much appreciated
Werner
Werner
Here is what I know, based on reviewing the wiring diagrams.
After 2012, the J431 Headlight Range Control module was functionally integrated into the J519 "Electrical System Control Module" (located forward of the drivers left knee).
The Front left and rear left level sensors connect to J519, which then sends the level signal over the CAN bus, to the headlights.
The Headlight Range Control (Level) module and level motor are located inside the headlight housing.
The AFS (cornering aim) control electronics and swivel motor is also contained within the headlight housing, getting the steering wheel angle signal from the CAN bus.
I am not sure why the diagram shows a front left and rear left level sensor, but your car only has the rear level sensor. My guess is that Audi saved some money in later production, by eliminating the front level sensor, which isn't really necessary to determine the rake angle of the vehicle (due to cargo weight loading in the rear). I have seen the deletion of the front level sensor in other VW/Audi products.
I think you might have to reprogram the CAN Gateway Module to tell it that the new AFS and the new Range/Level modules are present on the CAN bus. I believe there is a list of "vehicle installed modules" that needs to be edited.
Mezzo1161 (03-25-2020)
Hi S4'ed - that is great news .....
I can see the logic about eliminating the front sensor, especially with a heavy engine like the 3.0 TDI. A couple of questions if you don't mind:
1. Are there different versions of J519 (w/o and w/ AFS)?
2. Would you have the wiring diagram showing this setup (connection to the sensor and the headlights)? I am especially curious as the wiring diagrams i have are very different with both type of headlights....
Thanks
Werner
Thanks
Werner
I have no idea if there are different hardware or soft-coding differences between J519 w or w/o AFS. I would guess not, because although the level sensors are "processed" by the J519, the AFS does not need the level data to function, it only uses steering angle and road-speed data.
To get the electrical wiring diagrams, I suggest you subscribe to alldatadiy.com, for a one-year subscription ($29 I think) of unlimited access to the contents of the Audi Factory Service Manual.
S4'ed - you made my day.
I subscribed to alldataiy and on the first glance the wiring data shows the connections directly to J519 !!
Interestingly i sourced the workshop manual from eautorepair and also RepairManuals.co which are both omitting this change. As you said, wiring is different starting with MJ2013.
Will dig into this and if i get it figured out make a post on the solution - fingers crossed.
Again, thank you for your quick and competent replies
Werner
Werner
Quick update on the progress ....
I managed to compare the wiring diagrams between the BiXenon and the BiXenon w/ Cornering lights and there are a couple of differences:
Old Headlight levels are controlled directly from J519
New Headlights need a CAN signal to do this onboard
New Headlights also need a 12V for the built in controller and another ground on pin 14
Biggest issue is the CAN connection as the J519 i have (8K0907063DH) is missing this output. I found another version (8K0907063DL) that has these 2 pins installed in connector T16B.
When i switch on the car the headlights are dipping down, but do not swivel left/right. Also enabling AFS in VCDS generates a fault. Soooo - looks like i need a different J519 with the AFS control circuits included. I am a bit hesitant to buy a used module as i believe it has component protection and i am not sure i want to go thru the hassle of that. If someone can confirm that i would appreciate the feedback.
Will leave it as it stands for the moment unless i get the itch down the road.
Thansk
Werner
Thansk
Werner
Hi all, S4'ed
update on my progress with this retrofit ...
I swapped the existing BCM (Body Control Module Address 09) from (8K0907063DH) to ((8K0907063DJ). That one includes the control lines to drive the AFS Cornering Modules). Went into VAGCOM to set it up but so far are running into issues.
Let's start with the symptom. When i start the car the Headlights do their up/down dance (but not horizontal). Seconds later i am getting a 'Audi adaptive light defective' warning.
I have tried multiple settings in 09-Centr.Electr. that are associated with headlights but no change. There are multiple errors in 09, one of them is Component Protection. Others are related to the AFS modules being incorrectly coded.
Now, there is also an error in the CAN Gateway (19), 01771 - Control Module for Headlight Range (J431) - No signal). That is interesting as the new BCM does not have a J431, the CAN Gateway clearly remembers that there was one. I have looked at the Equipment list in the gateway but there is no entry for AFS to enable. I see an entry for 55-Headlight Range, i do not have the wiring for that module. Makes me think that i need a different CAN Gateway. Thoughts?
Yesterday i went to the AUDI dealer to get Component Protection removed from the BCM. They could not do it telling me that the system would not allow it as the BCM partnumber does not match the VIN (??). I can only assume that the system saw the mismatch between the BCM and Gateway. I have read about others that have been able to remove CP, although they may not have had these errors. Any thoughts on this?
Last but not least - I assume the cabling changes work as i can see that the BCM communicated with the AFS modules (J667 & J668).
Question:
Is there anything i am missing when setting up the CAN Gateway (8R0 07 468 D) or do i need a different version?
Any help is much appreciated.
Werner
Thursday,21,May,2020,10:36:29:16457
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WA1CMAFP5EA033454 License Plate: 2ND
Mileage: 104820km-65132mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 55 56
5F 62 6C 6D 72 AC
VIN: WA1CMAFP5EA033454 Mileage: 104820km-65132miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 401 J HW: 4G0 907 401 E
Component: 3.0TDI FSA H14 0014
Revision: 58H14---
Coding: 2A2A4012052603050000
Shop #: WSC 29413 001 1048576
ASAM Dataset: EV_ECM30TDI0118K5907401J 002014
ROD: EV_ECM30TDI0118K5907401J_002.rod
VCID: 3777C4CA8E0DCD3EFA-8062
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H16 1007
Revision: --H16---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 4B9F883AE28559DEAE-801E
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AM HW: 8R0 907 379 AM
Component: ESP8 quattro H09 0030
Revision: -------- Serial number: --------------
Coding: 231D1C03
Shop #: WSC 06335 000 00000
VCID: 0B1F483AAA0519DE6E-805E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 HP HW: 8K0 907 064 GP
Component: BCM2 2.0 H13 0641
Revision: 00002001
Coding: 0DA54040000000000000
VCID: 050B7E028C616FAE38-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 0213000293035011
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Component: KLIMA 3 ZONEN H04 0123
Revision: C1000000 Serial number: 01280820132045
Coding: 3621228000
VCID: 3973C2F2B019DB4E0C-806C
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:08:48
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000439094602
Coding: 264000918638AF004020000300001D0D0F1C4300A208022100 0008004000030200020035000000
Shop #: WSC 06325 123 12345
VCID: 7AF11DFEF59F105645-802E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130731 H11 0050
Serial number: 90243014130723155619
Coding: 01DD13
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21652870
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000308130164
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R72YY02
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H04 0012
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H04 0012
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 898881C6000000000001
6 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:40
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:40
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:40
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:41
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:41
01229 - A/C Humidity Sensor (G260)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:44
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H47 0610
Serial number: 003GPDB09P4K
Coding: 303634313432303030304A55304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 002004
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4797B40AFEEDBDBE8A-8012
Seat occupied recognition:
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R130000F34T
Crash sensor for side airbag: driver side:
Serial number: 6334MSME7C712675K
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME7D742B76V
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME14354E7ET
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME6135386CM
Crash sensor for front airbag: driver side:
Serial number: 63732SME5C3916787
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME5C391A489
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862MHR000GD
Coding: 000017
VCID: 4895B736FBF3B2C683-801C
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 A HW: 8R0 920 982 A
Component: KOMBIINSTR. H35 0563
Revision: 00300000 Serial number: WZE24PU8E
Coding: 8BB622000301D705020000
Shop #: WSC 26348 004 1048576
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z138120003
Coding: 80CF07FF00
VCID: 4C9D8B26EF8B5EE6A7-8018
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 40205B28291461796306
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 13232002495021200410
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:11:29
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.00 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:27:30
Freeze Frame:
Bin. Bits: 11111
Voltage: 12.50 V
Count: 6
Text: FFF1746C04828102
Text: 0000000000000000
Raw, Form. N/A: 000 000 000
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000072240714
Coding: 01581B00000000000000
VCID: 4281A51EDDCF98965D-8016
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0312714733
Coding: 010211
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU21.rod
VCID: 3F87ACEAA63DF57E32-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0313278237
Coding: 010211
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000071679201
Coding: 011D13205E00440004
VCID: 4FA79C2A1E9D65FEC2-801A
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H38 0507
Revision: 00001000 Serial number: 0012759425
Coding: 100000000001
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B7FD8FAB225E95E1E-806E
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0312970358
Coding: 0126023A20FA709584A0053600040047
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000714945
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
1 Fault Found:
03233 - Controls for Garage Door Opener (E284)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.20
Time: 21:43:38
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813018967303
VCID: 2D5BE6A2745177EE90-8078
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000071699308
VCID: 4E99812E19976CF6C9-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 20000000320427
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3973C2F2B819DB4E0C-806C
Address 55: Headlight Range
Cannot be reached
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156H90D7838629
Coding: 020007010000000001
VCID: 244D0386279BB6A64F-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 D HW: 8R1 035 746 D
Component: H-BNT-NA H40 0738
Revision: -------- Serial number: 204H+0D7595327
Coding: 160200060005A1EF51028B4E00000403140000000000000000
VCID: 3875C7F68B13C246F3-806C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130HM0D2804430
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001591133
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000072214610
Coding: 010C13204000240004
VCID: 4689B90EF1E7A4B671-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08--- Serial number: 525PA8-J36A3G5
Coding: 1020010
VCID: 346DF3C6577B2626DF-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B7FD8FABA25E95E1E-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000072214726
Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 131910095
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100.rod
VCID: 2B5FE8BA424579DE8E-807E
End-------------------------(Elapsed Time: 06:01)--------------------------
Question:
Werner
www.Ross-Tech.com
5F 62 6C 6D 72 AC
Revision: 58H14---
Revision: --H16---
Coding: 000001
Coding: 231D1C03
Revision: 00002001
Coding: 3621228000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:08:48
Coding: 01DD13
Coding: 02005C
H04 0012
H04 0012
6 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:40
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:40
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:41
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:41
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:13:44
Coding: 000017
Coding: 80CF07FF00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:11:29
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.00 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 63
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.21
Time: 09:27:30
Freeze Frame:
Bin. Bits: 11111
Voltage: 12.50 V
Count: 6
Coding: 010211
Coding: 010211
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 104824 km
Time Indication: 0
Date: 2020.05.20
Time: 21:43:38
Cannot be reached
Coding: 1020010
Chekm8
01-23-2009 08:33 AM
ArTT Vandelay
05-10-2008 03:45 PM
mikef
Audi allroad
10-25-2005 01:33 PM
