Cannot put gas in
Very weird problem has happened twice now. I pull into the self serve gas bar, turn off the car and remove the gas cap. But even though its mostly empty I can't put any gas in because the Q5 seems to be blowing air out of the tank which just shuts off the flow of gas. The first time it happened I was thinking did I forget to turn off the car? When I got home it wasn't blowing air out. Then it happened a second time and no it was definitely off so I turned it on for a second (didn't start it though) then turned it off and all was well again.
Anyone else have this issue? I tried a search and couldn't find anything similar. |
Happened once early on. Only drove a short distance about a mile before it happened. Waited a minute or so and then it was fine to fill.
Originally Posted by HarmsWay
(Post 24426265)
Uh, yes I'm holding the nozzle right.
This may be relevant...
I did find that the '13 3.0T gas receiver is a lot tighter than what it was in the '11 2.0T I had previously. I wrote it off as the car being new (a virgin) and being a little tight, but she had not loosen up yet. It could be that there is not enough space for any air to escape and that it produces some sort of back pressure? Just speculating... . |
Originally Posted by Reggie
(Post 24426293)
Are you holding the nozzle or putting it on automatic. Have you readjusted the angle the nozzle goes into the tank?
(Post 24426312)
Originally Posted by georgehf
(Post 24426484)
In my wife's BMW, the gas shuts off immediately at some gas stations. ...
:confused: |
I had this problem once with a Nissan Maxima. Problem was a bad evap charcoal canister. You can check the evap canister vent filter or valve first for clogs. I don't know if these parts are even applicable to our Q5's, but just sharing my experience with this same problem from a different vehicle.
When i went for a fill up last week, when i opened the cap, i heard a pressure coming out too. I wait and then i've put in the nozzle. No problem filling up.
Originally Posted by Parsec
(Post 24426585)
^^^This. Have the dealer investigate assuming we're still under warranty. Not an uncommon problem when you can't pump gasoline in. |
