Car wont start - P0506 00 [101] - RPM Lower than Expected
2012 Q5 Premium 2.0T
Went to start the car this afternoon and it started to shake violently. I shut it off and tried to restart it, but it wont turn over. Battery reads 12.4v and the car cranks just wont start. After scanning it that's the only engine code that came up. Tried clearing it, but it came back immediately. There were a couple other codes, but I don't think they are related. If I knew how to post the log without making a wall of text I would. Any suggestions? Google wasn't much help.
1 Fault Found:
4010 - Idle Control System
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 68414 km
Date: 2017.06.29
Time: 11:12:54
Engine speed: 757.00 /min
Normed load value: 22.0 %
Vehicle speed: 0 km/h
Coolant temperature: 54 °C
Intake air temperature: 30 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.193 V
Unlearning counter according OBD: 40
Readiness: 0000 0000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 68414 km
Date: 2017.06.29
Time: 11:12:54
To post your auto scan in a scrollable box. Works on other vbuilletin sites, should work here.
[CODE] Your autoscan [/ CODE]
and remove space between / and code
Thanks
Code:
Chassis Type: FP (8T0) Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77 VIN: WA1CFAFP9CA136495 Mileage: 68410km-42508miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb Part No SW: 8R0 907 115 P HW: 8K2 907 115 D Component: 2.0l R4/4V TF H20 0002 Revision: E1H20--- Coding: 0121010A290F0160 Shop #: WSC 06208 000 00000 ASAM Dataset: EV_ECM20TFS0118R0907115P 001002 ROD: EV_ECM20TFS0118R0907115P.rod VCID: 4182BD15D0EADF49A6-8014 1 Fault Found: 4010 - Idle Control System P0506 00 [101] - RPM Lower than Expected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 68414 km Date: 2017.06.29 Time: 11:12:54 Engine speed: 757.00 /min Normed load value: 22.0 % Vehicle speed: 0 km/h Coolant temperature: 54 °C Intake air temperature: 30 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 13.193 V Unlearning counter according OBD: 40 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb Part No SW: 8R0 927 158 T HW: 0BK 927 156 AJ Component: 0BK 20TFSIUSA H16 1006 Revision: --H16--- Coding: 000002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002018 ROD: EV_TCMAL551211_002_AU48.rod VCID: 4E98962911B430312B-801A No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb Part No SW: 8R0 907 379 H HW: 8R0 907 379 H Component: ESP8 quattro H06 0110 Revision: -------- Serial number: -------------- Coding: 121D10 Shop #: WSC 06335 000 00000 VCID: 458AA905CCC2F3699A-8010 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 FL HW: 8K0 907 064 FL Component: BCM2 2.0 H11 0602 Revision: 00002001 Coding: 09854000000000000000 Shop #: WSC 06335 000 00000 VCID: 7F06FBEDEE9E69B990-802A Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A Component: FBSAUDIB8 IDG H60 0072 Serial number: 0512000046138020 Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 2312000144824013 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01060720120932 Coding: 64012000 Shop #: WSC 06335 000 00000 VCID: 0004781193601641E9-8054 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 CE HW: 8K0 907 063 P Component: BCM1 1.0 H30 0410 Revision: 10030001 Serial number: 00000001375087 Coding: 690000B1063CA7010000080300007F7F0F1C460802000161000000 Shop #: WSC 06335 000 00000 VCID: 74EC24C1D7D83AE1FD-8020 Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB Component: WWS416 120627 H11 0050 Serial number: 90243014120621113303 Coding: 01DD13 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 20177627 Coding: 024D25 Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000000207121166 Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C Component: HOMELINK H01 0010 2 Faults Found: 03188 - Bulb for Side Marker Light; Front Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 204 Mileage: 68152 km Time Indication: 0 Date: 2017.06.27 Time: 06:32:00 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 204 Mileage: 68152 km Time Indication: 0 Date: 2017.06.27 Time: 06:32:00 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8R0-959-655.clb Part No SW: 8R0 959 655 F HW: 8R0 959 655 F Component: AirbagVW-AU10 H45 0610 Serial number: 003GPD90KPWE Coding: 303633313432303030304A55304C38523053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaAU10SMEAU416 002004 ROD: EV_AirbaAU10SMEAU416.rod VCID: 4796A30DFECEE17968-8012 Seat occupied recognition: Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A Component: BF-Gewichtss. H02 0040 Serial number: 5810000R1200008RY3 Crash sensor for side airbag: driver side: Serial number: 6334MSME6E163964M Crash sensor for side airbag: front passenger side: Serial number: 6344MSME6F45311AJ Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME5C1C396C. Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME7E193770Q Crash sensor for front airbag: driver side: Serial number: 63732SME0920035EW Crash sensor for front airbag: front passenger side: Serial number: 63832SME471B4E727 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H17 0014 Revision: -------- Serial number: 90372LGA001TH Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 3D7AC1E5A412BBA9C2-8068 Component: E221 - MFL H02 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb Part No SW: 8R0 920 950 K HW: 8R0 920 950 K Component: KOMBIINSTR. H12 0261 Revision: 00100000 Serial number: N3752ZX6D Coding: 8B1622000300D705020000 Shop #: WSC 06335 000 00000 VCID: 3E78C6E9A914A0B1DB-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 AF HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0120 Revision: GB901054 Serial number: 5400G126228100 Coding: 00C303 Shop #: WSC 06335 000 00000 VCID: 050A69058C423369DA-8050 Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181 Component: J367-BDM H07 0141 Serial number: 00000000003790737613 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb Part No SW: 8T0 035 785 A HW: 8T0 035 785 Component: SG ext.Player H08 0290 Revision: 00000000 Coding: 020302 Shop #: WSC 06335 000 00000 VCID: 3972D5F5B03A8789EE-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 R HW: 8K0 959 793 P Component: TSG FA H02 0506 Revision: Serial number: 0000034482677 Coding: 011D03204000440004 Shop #: WSC 06335 000 00000 VCID: 4FA68B2D1EBE393920-801A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 FL HW: 8K0 907 064 FL Component: BCM2 2.0 H11 0602 Revision: 00002001 Serial number: 0179685124 Coding: 0126063A20FA441484B0053200000000 Shop #: WSC 06334 123 12345 VCID: 7F06FBEDEE9E69B990-802A Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000544231 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H03 0220 Serial number: 0123456789ABCDEFGHIJ Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J394EE20SKB13 H03 0220 Serial number: 0123456789ABCDEFGHIJ 1 Fault Found: 00218 - Humidity Sensor (G355) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 223 Mileage: 67668 km Time Indication: 0 Date: 2017.06.21 Time: 13:42:15 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb Part No SW: 8R0 035 223 G HW: 8R0 035 223 E Component: DSP STD H11 0460 Revision: 00000000 Serial number: 00000000000001 Coding: 0203010102 Shop #: WSC 06335 000 00000 VCID: 3064E8D1634046C159-8064 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 R HW: 8K0 959 792 P Component: TSG BF H02 0506 Revision: Serial number: 0000034582054 Coding: 011D03204000440004 Shop #: WSC 06335 000 00000 VCID: 4E98962919B430312B-801A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 20000000232270 Shop #: WSC 00000 000 00000 VCID: 346CE4C197587AE13D-8060 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 R HW: 8T1 035 186 R Component: Con3 Sirius H06 0351 Revision: 00000011 Serial number: AUZ5Z6L1765727 Coding: 04020002010585004359070800 Shop #: WSC 06335 000 00000 VCID: 4688AE09F1C4F87193-8012 Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G Component: Display 2 Faults Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 3 Mileage: 50900 km Time Indication: 0 Date: 2017.01.12 Time: 15:36:15 03157 - Functionality limited due to Communications Disruption 000 - - - Intermittent Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 3 Mileage: 50900 km Time Indication: 0 Date: 2017.01.12 Time: 15:36:15 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 D HW: 8K0 959 795 D Component: TSG HL H01 0506 Revision: Serial number: 0000034226204 Coding: 010C03204000240004 Shop #: WSC 06335 000 00000 VCID: 438EB71DC2F6CD59B4-8016 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 D HW: 8K0 959 795 D Component: TSG HR H01 0506 Revision: Serial number: 0000034239401 Coding: 010C03204000240004 Shop #: WSC 06335 000 00000 VCID: 438EB71DC2F6CD59B4-8016 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 336 F HW: 8T0 862 336 E Component: FSE_256x BT H45 0660 Revision: 00000000 Serial number: 00000005277552 Coding: 0010370 Shop #: WSC 06335 000 00000 VCID: 3E78C6E96914A0B1DB-806A No fault code found.
Raycing (08-23-2021)
Heard back from the shop today with a small update. No compression, which leads them to believe something with the valve train is out of wack. Wont know for sure until they dig in deeper. But could very much likely be the tensioner.
The tensioner most likely failed, it usually happens when you first start the car, the timing chain jumps a few teeth, the pistons hit the valves and bends them, thus no compression. The fix at an Audi dealer is usually $7K+..........
