dealer quote front pads/rotors
$1,140 complete....parts $890, labor $250. I dyi'ed several S4's many times over the years. Hard to believe the outrageous parts costs, whereas labor is reasonable for Audi.
Originally Posted by bpp
(Post 25179485)
$1,140 complete.,,,parts $890, labor $250. I dyi'ed several S4's many times over the years. Hard to believe the outrageous parts costs, whereas labor is reasonable for Audi.
Originally Posted by Warhead
(Post 25179509)
Always cheaper to do it yourself.
Not sure what you were expecting. The Q5 is a heavy car, so brake rotors are gonna cost. That's relatively cheap. An OEM full brake job for my RS5 is more than twice that for comparison. These are not lightweight eco cars. You can consider aftermarket parts, but good aftermarkert rotors are not gonna be that much cheaper. Here are some options and prices.
https://www.ecstuning.com/Audi-Q5-Qu...raking/Rotors/ However, you may wanna find out exactly what state your brakes are in. Dealerships always want to do a full brake job the moment either the front or rear pads are worn, but the rotors don't necessarily need to be replaced. They have about 1-2 mm of wear life on them. You should measure them and check against the minimum width stamped on the hat. I still have my original rear rotors on my RS5 for example and I'm on the second set of rear pads. I replaced the front rotors with better aftermarket rotors and I'm now on the third set of pads. The aftermarket rotors were barely worn when I replaced the pads for the second time. Dealerships just don't want to be liable, so they recommend a full brake job every time, but if you know what you are doing and are informed you don't have to replace rotors if they still have life on them for example. |
Originally Posted by hollowplayer
(Post 25179865)
you need VCDS, EB retraction for the rear.
Replaced my rotors and pads last weekend for $300, very easy job. |
(Post 25179485)
(Post 25179485)
(Post 25179878)
Not true, VCDS makes it easier but you can manually retract them.
OEM excellent so far, AUDIUSAPARTS.COM
Hello Gents,
so I always get my OEM parts from them, excellent price(about 20% off , +no tax, free shipping). Rotors as re 315$+tax/pp , got them @237$👍. small shop would do them for couple hundred. I'm due for full brake job, dissatisfied with other aftermarket rotors and pads, so going OEM,- rear pads I got, Akebono, as s recommended by the mech. hope that helps, cheers, Bob |
