Rear Bumper Light Replacement
Old 08-03-2013, 05:18 AM
cheewy's Avatar
Default Rear Bumper Light Replacement
One of the two rear bumper light bulbs on the passenger side went out as I have a bulb out warning on my display.
Has anyone ever changed one of these....how difficult and what size bulb is needed. I looked at the owners manual and it seems like it won't be too difficult?
Old 08-03-2013, 05:42 AM
spijun's Avatar
Simple and easy. Here's a video Instruction:
http://www.carcarekiosk.com/video/20...hts/tail_light
Old 08-03-2013, 06:50 AM
AudiWorld Expert
Reggie's Avatar
Suggest you look at replacing it with one of the LEDs that do not throw a code - ECS carries them as well as some other places
Old 08-03-2013, 07:30 AM
spijun's Avatar
Could standard LED bulbs but you need VCDS, this works
Module 46 Central Convenience
> Security Access 16 > 16017
Adaption 10 > Channel 181 > Convert your decimal number to binary (for example decimal is 65535, converted to binary = 1111111111111111), then change bit 10 and 11 from 1 to 0 (new binary value becomes 1111001111111111, which is 62463 in decimal) > Enter the new binary value > Test > Save
No more errors with standard LED bulbs
Only for reverse bulbs
Old 08-03-2013, 11:26 AM
cheewy's Avatar
Thanks for the video! Going to have to take take of the bulb soon. Find the bulb out warning very annoying.
Old 08-03-2013, 04:19 PM
Otto Man's Avatar
Default Bulb Replacement
I think it stinks we have to replace bulbs after a couple years. There is a TSB on this as well. Take your Q5 in and have them replace all bulbs and clean contacts today. There is a contact problem Audi knows about. I did it.
Old 08-03-2013, 05:12 PM
cheewy's Avatar
Is there a link to this TSB? I'm shocked because I've only had this car since May '12. Bulbs should last longer this, no?
Old 04-07-2014, 04:17 AM
Heat00's Avatar
do you know what bulb # it is, before I pull it out. can't seem to find it in the manual. guess I will take out and take bulb to store... what a hassle... I agree, shouldn't be burnt out bulbs yet on a 2012.
Old 04-07-2014, 04:37 AM
AudiQ5sleeper's Avatar
194 BULB
Old 04-07-2014, 05:05 AM
spijun's Avatar
All bulbs
hojbjerg
Q5/SQ5 MKI (8R) Discussion
01-30-2015 10:38 AM
Audilife88
Q7 MK 1 Discussion
09-16-2014 01:36 PM
Kc Taylor
Q7 MK 1 Discussion
03-18-2012 04:49 PM
tgt
01-13-2011 03:33 PM
olneymd
01-21-2004 12:36 PM
Quick Reply: Rear Bumper Light Replacement
