ECU info obtained with Carista 3.5 beta-7 for Android:
here is the latest report it get two fault codes, should i be concerned?
Infotainment system
Part #: 8R1035664J
Fault codes: 03157 Function Limitation because of Communication Failure
Heater & air conditioning
Part #: 8K1820043AQ
Fault codes: 01207 Control Module for Auxiliary Heater (J364)
================ FULL DIAG REPORT ==============
VIN: WA1M7AFP9GAxxxxxx
CAN network gateway
Part #: 8R0907468AA
Coding: 80CF07FF00 (hex)
Component: GW-BEM 5CAN-M
[No fault codes]
Ignition authorization
Part #: 8K0907064KP
Coding: 0DA54040000000000000 (hex)
Component: BCM2 2.0
[No fault codes]
Central electronics
Part #: 8K0907063DJ
Coding: 26000096863CAFE20900488300003D0D4F9CC708A609022100 0008004400070200040034000000 (hex)
Component: BCM1 1.0
[No fault codes]
Body/convenience system
Part #: 8K0907064KP
Coding: 0126023A20FA709587B0053600040047 (hex)
Component: BCM2 2.0
[No fault codes]
Driver's door
Part #: 8K0959793R
Coding: 011D13215E00440004 (hex)
Component: TSG FA
[No fault codes]
Front passenger's door
Part #: 8K0959792R
Component: TSG BF
[No fault codes]
Rear left door
Part #: 8K0959795G
Coding: 010C13204000240004 (hex)
Component: TSG HL
[No fault codes]
Rear right door
Part #: 8K0959795G
Component: TSG HR
[No fault codes]
Driver's seat
Part #: 8R0959760D
Coding: 01581B00000000000000 (hex)
Component: MEM-FS
[No fault codes]
Part #: 8K1820043AQ
Coding: 6639228080 (hex)
Component: KLIMA 3 ZONEN
Fault codes:
Steering wheel
Part #: 8K0953568M
Coding: 00003F (hex)
Component: Lenks.Modul
[No fault codes]
Back-up camera
Part #: 8R0907441A
Coding: 1020010 (decimal)
Component: J772__Rearview
[No fault codes]
Trunk
Part #: 8R0827851D
Coding: [none]
Component: J605 Master
[No fault codes]
Instrument cluster
Part #: 8R0920932A
Coding: 8BAF22001E010008020300 (hex)
Component: KOMBIINSTR.
[No fault codes]
Parking brake
Part #: 8K0907801N
Coding: [none]
Component: EPB-4
[No fault codes]
ABS
Part #: 8R0907379AS
Coding: 19150C03 (hex)
Component: ESP8 quattro
[No fault codes]
Steering angle
[failed to connect]
Airbags
Part #: 8K0959655R
Coding: 303635313832383132304A55304C38523053 (hex)
Component: AirbagVW-AU10
[No fault codes]
Engine
Part #: 8R0907551F
Coding: 2A2A0034054601060000 (hex)
Component: 3.0l V6 TFSI
[No fault codes]
Transmission
Part #: 8R0927158AM
Coding: 000002 (hex)
Component: 0BK 30TFSIUSA
[No fault codes]
Suspension
Part #: 8R0907364C
Coding: 030181 (hex)
Component: DAEMPFUNGS-SG
[No fault codes]
Adaptive cruise control
Part #: 8R0907561A
Coding: 003348 (hex)
Component: ACC3
[No fault codes]
Lane-change system
Part #: 8T0907566B
Coding: 010211 (hex)
Component: SWA Master
[No fault codes]
Radio
Part #: 4G0035082G
Coding: 020007020100000001 (hex)
Component: Radio U SIRIU
[No fault codes]
Infotainment system
Part #: 8R1035664J
Coding: 1602000600058BFF7F228F4E00000403F40000020300000000 (hex)
Component: H-BN-NA
Fault codes:
Power steering
Part #: 8R0909144Q
Coding: 100000010001 (hex)
Component: RCevo
Fault codes:
1052432 Manufacturer-specific code
7341632 Manufacturer-specific code
Infotainment system
Part #: 8R1035664J
Part #: 8K1820043AQ
CAN network gateway
Part #: 8R0907468AA
[No fault codes]
Part #: 8K0907064KP
Component: BCM2 2.0
[No fault codes]
Central electronics
Part #: 8K0907063DJ
Component: BCM1 1.0
[No fault codes]
Part #: 8K0907064KP
Component: BCM2 2.0
[No fault codes]
Driver's door
Part #: 8K0959793R
Component: TSG FA
[No fault codes]
Part #: 8K0959792R
Component: TSG BF
[No fault codes]
Rear left door
Part #: 8K0959795G
Component: TSG HL
[No fault codes]
Rear right door
Part #: 8K0959795G
Component: TSG HR
[No fault codes]
Driver's seat
Part #: 8R0959760D
Component: MEM-FS
[No fault codes]
Part #: 8K1820043AQ
Fault codes:
Steering wheel
Part #: 8K0953568M
[No fault codes]
Back-up camera
Part #: 8R0907441A
[No fault codes]
Trunk
Part #: 8R0827851D
Coding: [none]
[No fault codes]
Instrument cluster
Part #: 8R0920932A
[No fault codes]
Parking brake
Part #: 8K0907801N
Coding: [none]
Component: EPB-4
[No fault codes]
ABS
Part #: 8R0907379AS
[No fault codes]
Steering angle
[failed to connect]
Airbags
Part #: 8K0959655R
[No fault codes]
Engine
Part #: 8R0907551F
[No fault codes]
Transmission
Part #: 8R0927158AM
[No fault codes]
Suspension
Part #: 8R0907364C
[No fault codes]
Part #: 8R0907561A
Component: ACC3
[No fault codes]
Lane-change system
Part #: 8T0907566B
[No fault codes]
Radio
Part #: 4G0035082G
[No fault codes]
Infotainment system
Part #: 8R1035664J
Component: H-BN-NA
Fault codes:
Power steering
Part #: 8R0909144Q
Component: RCevo
Fault codes:
Sounds like the infotainment system couldn't find a phone or media that it was expecting. Maybe because that wasn't plugged in, maybe because the system is having a hardware failure. Clearing the code and trying all functions to generate it again, or confirm they are working, might be in order.
The auxiliary heater itself was the subject of a recent recall notice in some models. Your dealer might know if this relates to the failure and program or not. If you weren't aware of this, check your VIN with the dealer.
M3iRiSH
08-01-2001 06:50 PM
