Electrical Diagram Help for keyless harness
Help needed with Audi Q5 Connector 20 pin right front A pillar (T20m) connected to T27c. Can one please explain how to connect to T20m?? For the moment I have connected from T32e to T27C and from T27c to G606 sensor. How can I connect cables the proper way?? Where is the T20m connector located?
I have trouble understanding the following connections:
T27c/3-T20m/9
T27c/23-T20m/18
Is this a cable solder between these cables. So I just get an extra cable and solder it to cable that goes to T27c/3 and the other side to cable that goes to T20m/9??
then the same for the one below, I get another cable and solder it to cable that goes to T27c/23 and other side to T20m/18??? The diagram below shows a connection between them.
Is this the correct way?? Also I need to find out where is connector T20m. A part number especially a photo of location will help. All T27 connectors are on the door separation so that is easy. T20m 20 pin connector on the front right A pillar any ideas where it is?? Thanks
T27c/3-T20m/9
T27c/23-T20m/18
Just to help maybe get some ideas. Just observed the following:
These are the following notes on the connection (see last picture and first with description)
* Gradually discontinued
*2 Gradual introduction
I believe that T27 was discontinued at the RHD front door, and repaced by a T20 connector in later manufacturing years. So I think I have the solution in front of my eyes.
I have no T20 but a T27 only (2009 Q5 is old) and there is no connection between the two connectors in my car because it is either a T20 or a T27. My gut feeling of using the same pins as in the other T27 connections was correct. (all connections from T32e to T27 pin 3). The German guide had T20m/pin9 and this is the second mistake I find.
When I write I usually find a solution, because I always memorize. On the 3rd of July I will test my Kessy and Start button.
Sloooo4esT
Audi Original "S" Cars
07-23-2006 09:54 AM
Hanzhi
11-07-2003 07:50 PM
