Fuse box mapping for dashcam
Old 12-21-2016, 06:23 PM
Zigaroo's Avatar
Default Fuse box mapping for dashcam
Hi all,
i know there are alot of pictures out there showing Q5 (2012) fuxebox but i'm looking for something that would show which ones are "accessory" type slot and which ones are "always battery".
thanks for your help.
Old 12-21-2016, 07:32 PM
waninae39's Avatar
check my past post here
https://www.audiworld.com/forums/q5-...nning-2910517/
Old 12-21-2016, 08:44 PM
riceboy22's Avatar
For my dashcam installation, on the driver side, I tapped the second fuse from the bottom in column A (left fuse bank) which is used for the side assist. For the battery line, I tapped the blue 15 amp fuse in column B (center fuse bank) which I think is the fuse for the horn. The details of my install are here.
I don't have a diagram that has each fuse marked as accessory versus always on, but here's the standard diagrams for reference. If you get a $10 circuit tester, you can know pretty definitively.
Old 12-22-2016, 12:50 PM
Sigq5's Avatar
Riceboy,
Thx for sharing this info. I have been thinking about adding dash cams and would be interested in which you got and what has been your experience so far.
Thx
Old 12-22-2016, 02:54 PM
riceboy22's Avatar
Originally Posted by Sigq5
Riceboy,
Thx
I have the Thinkware F770. I wrote up a review here: Thinkware F770 Dashcam Installation and Review.
TLDR; I think the Thinkware F770 is awesome so far. I considered this and the Blackvue, but the deciding factor was that the F770 had 1080p cameras front and rear while the Blackvue was 1080p only for the front camera. I think the Blackvue is a nicer looking unit if that is important. Installation was really easy.
Old 12-23-2016, 05:57 PM
Zigaroo's Avatar
excellent, thanks for sharing. very helpful.
i bought the incarbite OE wifi dashcam. it fits on the mirror directly therefore not in the way.
https://incarbitestore.com/collectio...fit-car-camera
Old 12-31-2016, 11:41 AM
Zigaroo's Avatar
finallly got it installed, it took me 35 min. and it was quite easy. I didn't even take the Pillar A out, i just removed the Airbag tag/snap-in and that loosen the Pillar. i ran the cable in the ceilling then the pillar.
The unit is about 3/4 inch longer then original cover and 1/2 thicker.
Before
After. it's not blocking the view.
fuse wiring
bacccc
09-18-2018 05:13 PM
riceboy22
Q5/SQ5 MKI (8R) Discussion
10
01-24-2018 09:49 PM
Alpine 87.5
Quattro: Turbo / Ur / Sport
02-06-2008 02:21 PM
KMHPaladin
12-27-2004 08:34 PM
unknownvirus
01-23-2004 08:48 PM
Quick Reply: Fuse box mapping for dashcam
