Headlight adjust after lowering
Couldn’t find anything in search - is there a diy procedure to re - level the headlights after the vehicle has been lowered?
Just had the H&R springs installed on my 2016 Q5 2.0
now headlights are angled down too low.
Thanks.
Thanks.
This is pretty much what my shop did when they installed a Bilstein + Eibach B12 Proxit set (-3cm) to my Q5:
Just did what you did on my 2016 Q5 2.0. H&R sport springs & 20" wheels. Easy solution you can do yourself. Open the hood & look @ the top rear of both headlights & you will see a small white Philips head screw. This is your up/down adjustment. Use a fine screwdriver. If I remember correctly clockwise raises & counter clockwise lowers. Find a level site where you can shine on a flat vertical surface & stay back about 15-20 ft. That's it.
I have an obd 11 and watched that video- unfortunately I get stuck at the part where you have to enter a “channel” I Have No idea what channel to enter - According to the video you have to put the headlights in service mode before you make the adjustments with the white screws.
ewu519
A4 (B9 Platform) Discussion
20
08-22-2019 03:44 PM
Dville
08-20-2017 01:36 AM
DON2.0T
09-15-2005 07:02 PM
