Headliner Rattle Fix
Old 10-08-2018, 02:31 PM
eus
eus's Avatar
Default Headliner Rattle Fix
If you have these symptoms, I have a fix for you:
1) You hear a creaking or popping noise above your head when your car goes over bumps, or when entering / exiting driveways
2) Does not happen if it is a hot day (80F+) outside and your car has been parked in the sun
3) These noises still happen if your sunroof is open
This is not a fix for the sunroof rattle. I thought I had that issue, but finally found the cause to be the headliner, and not the sunroof. I am out of warranty, so taking it into the dealer is not an option. It is a fairly ugly hack, but my car is dead quiet now!
First step is to cut strips of card stock. I used some marketing postcards that were sent to me (Bed Bath & Beyond card work great, I had something a little thicker). Cut several strips (7cm long, 1cm wide) out. You will then need to shove the strips between the plastic roof and the metal rim of the headliner, for me, I needed to put 3 strips thick in between that metal rim to keep it from wiggling. Slide the strips in one at a time, and stack until tight. These strips of card stock act as a wedge to keep the metal rim of the headliner rubbing and rattling against the plastic part of the roof. Repeat this process for the length of the front part of the headliner. Cover the strips with electrical tape to keep the card stock from coming loose, and to make this less ugly.
I know it's a relatively unorthodox / ugly / amateurish hack, but the silence is golden. That rattle was driving me insane.
Old 10-10-2018, 07:31 AM
AUDIQ52.0's Avatar
Hi Eus,
Thanks for post.
I have same problem.
Do you maybe have some more pictures, so we can recognize where to put the cards?
Old 10-11-2018, 08:07 AM
eus
eus's Avatar
I've taken a picture of one of the sections, under the electrical tape. Put the strips on the plastic roof part, next to the metal rim, and slide them under the metal rim. You just need to fill the gap until tight so the two components stop moving and stop rubbing against each other directly. I had about a 1-2mm gap, once it was stuffed, the noises stopped.
I'm surprised that Audi used such different materials right next to each other with no (or insufficient) padding in between. Plastic and Metal will expand and contract at different rates, which is why I have this rattle/creaking when it is below 80F.
Hope this picture helps:
Old 10-11-2018, 09:54 AM
AUDIQ52.0's Avatar
Now is much clear , thank you vm. I hope that will solve the problem. During weekend I will try to fix it, and inform you abot the results.
Old 10-15-2018, 10:37 AM
AUDIQ52.0's Avatar
Default Rattle fixed
I have done as you described in your post, now everythig is quiet as before. Thanks a lot!!!
Old 10-17-2018, 08:58 AM
motoguy128's Avatar
Where is this located? at the front of the moof roof opening? Hard to tell from the closeups.
Old 10-17-2018, 09:45 AM
eus
eus's Avatar
Correct, at the front of the moon roof opening. It is the area right above your head when you are driving. To give you a frame of reference, the wind deflector is the mesh fabric at the top left corner of the second picture. I had to do several strips along the entire front of the moonroof opening.
Bruce B
Q5/SQ5 MKI (8R) Discussion
47
12-07-2018 01:52 AM
Audeye A6
08-18-2005 11:39 AM
Polar
05-05-2003 02:55 PM
Stu S.
08-29-2002 09:30 PM
badmonkey
02-08-2002 07:41 AM
Quick Reply: Headliner Rattle Fix
