Improving Bang and Olufsen Stereo
#103
Interested in adding an amp/sub to my 2018 but this seems to be similar. There's 2 channels going to the sub. Is it correct that I just need pos and neg from one channel for high level input to the new amp?
Is there any issue using those high levels that are already amplified and putting them into another amplifier?
#104
CERWIN-VEGA MOBILE VPAS10 VEGA 10" Powered Active Subwoofer Enclosure
Slim 2ohm subwoofer
450W max
200W RMS @ 2ohm @ 100Hz
0dB-12dB bass boost
35Hz subsonic filter
75Hz-150Hz low-pass filter
0deg /180deg phase switch
PWM MOSFET power supply
Thermal protection circuit
Adjustable input sensitivity
RCA & high-level inputs
Delayed soft remote turn-on
Includes remote subwoofer control
Dim: 2.56"H x 13.58"W x 9.65"D
Slim 2ohm subwoofer
450W max
0dB-12dB bass boost
#105
The B8 model has only 2 wires going to the factory sub. By your description it sounds like the B9 has 4. Probably a stereo pair so 1 set should do the job. Then again many amps do allow for stereo high level inputs.
Scroll up about 30 messages and see my post on amping up the sub & adding a new box altogether.
#106
As long as the Amp you're adding has high level inputs you should be all set.
#107
Get a pair of those little speaker to RCA adapters and your install will be quick and clean.
I'd also check to see if the cig in your car switches off with the button and not the door opening. Some times I like to sit with the car off and finish out a song. Find a switch power that works off the door and not the start button.
#108
If you're using the HX300 then I'd use both high level inputs from the factory amp just in case bass is sent to one channel and not the other. Unlikely but an easy extra step.
Thanks
#110
My CV spare tire arrives on Monday. I will get it installed and update fitment and sound. I currently have this https://www.jbl.com/car-subwoofers/J...oofers#start=1 Louder than stock but I want it out of the way.
