Metallic 'sliding' noise when making turns
AudiWorld Expert
This is one of the weirdest noises I've heard on a car. When you turn (regardless if braking or not, regardless if accelerating or not), you hear this metallic noise, as if some part was sliding from one side of the car to the other. It sounds like the noise is coming from the inside of the car, but I once heard it from the outside as well, when wife was driving.
Now, you need to be making subsequent left/right turns for it to occur. If you keep making only right turns, you won't hear it again until you make another left turn, and vice versa. This would support my suspicion that it is something that is sliding from one side to another, and needs an opposite turn to slide again.
Anyone had this happen? What is it? It's driving me nuts.
https://www.audiworld.com/forums/q5-...-seat-2842924/
AudiWorld Expert
AudiWorld Expert
@ex-quattro PETE heya, i actually started to have this issue from today...the EXACT thing.. where on turns, I hear something slide over, and it'll only happen if I go left after right and vice versa. So something is definitely sliding around.
I feel like I hear it above me, which assumes that something's gone loose in the headliner / sunroof mechanism... but I'm not 100% sure. Would love it if you've found the issue and solved it.
Many years ago when washing my Corrado, I found a pair of locking pliers in the roof space behind the sunroof. Never heard any noise from them while they were there though. No idea what your noise can be, but noises like this can be infuriatingly hard to track down sometimes. Best of luck!
To second Tinpusher's comment I recently had an oil change and the front control arms replaced by the dealer, was checking my oil level and found a short handled ratchet wrench under the hood just below the windshield on top of the plastic panel where the wiper arms are attached.
I'm having the exact same issue on my brand new 2021 Q5 and it's driving me nuts. If you turn right after left after right, you can hear a slight thump as the object hits one side of the vehicle and the other side and so on. It sounds like it's definitely coming from the headliner or roof. Any ideas/suggestions?
