Need help to replace parts of my Q5
Hey guys... I own a 2010 Q5 2.0TFSI CDNC which I bought used about 3 years ago.
I just did a general check up on it as it was asking for oil top ups every 300 kms now.
Car needs replacement on several parts which Im gonna buy online because getting them done at the Audi shops here is just too costly.
I need to replace the followings:
1. Engine mounts
2. Pistons, rings, conrods
3. Control arms bushings
4. Brake discs and pads
My questions:
1. Should i get engine mounts with sensors or not? Not sure if the 2010 models come with sensors.
2. Should i replace the conrods as well? Most online sellers only sell the pistons and rings set.
3. Should i replace the whole control arms or just the bushings would be sufficient?
I think that would be my questions for now. Any help is appreciated.
Thanks!
1. Engine mounts
My questions:
Thanks!
Fun times ahead, 2009 2.0T owner here, went through all those in your list but Control arms. The main issue (oil consumption) is the one to tackle first, you should add a distribution kit and a water pump (metal propeller). Not sure where you are located, but you should be able to contact any reputable parts store with your VIN number and ask for help on OEM parts, there's a lot on your list and again, depending on where you live, just the engine work could cost $3K in parts + labor at an indy shop. Good luck!
Oil Consumption could mean something is leaking as well. Have you checked under the car? I bought a 2010 Q5 3.2 about 2 and a half years ago now and my seals were leaking. I had aftermarket warranty so last year they replaced some seals around the oil filter and somewhere on the back of the motor. The vacuum pump was leaking too and I replaced that on my own for 150ish where Audi wanted $600. Then just recently they replaced my valve cover seals and oil pan seal. They did an inspection on my suspension and told me I need to replace some bushings on the front end too but I will wait on that.
For the control arm bushings it is easier to get it complete with bushings installed unless you can find the bushings separately and have a press to press them out and press them back in...
It's a 2.0T: "I own a 2010 Q5 2.0TFSI CDNC which I bought used about 3 years ago", I've got the same engine code, worst batch ever, I'm 99% sure he needs new pistons, rings, conrods, distribution kit and water pump. And I forgot to mention the PCV valve, and very likely the RMS, not the best batch that CDNC engine code
Im inclined to just buy the cheaper after market parts and hope it can give me a few more years of usage.
I doubt that its still sellable with the many costly fixes it needs.
Have you tried pushing it to Audi to get it all fixed since its definitely a defect on their side?
Might consider the timing chain (belt?) while the engine is open, since the Audi engines are "interference fit" and if that chain fails, you're in for a major engine job again. IIRC the spec should be to change it at somewhere between 50-100k miles. If that was never done, might as well do it now.
s4sleeper
18
11-18-2007 09:08 AM
BJC::wokka wokka
03-26-2006 04:33 PM
snichols
11-15-2003 08:59 AM
Imola Ghost
01-05-2003 07:58 PM
ADAMB
08-16-1999 09:21 PM
