Oil leak...how to resolve?
Hi Everyone:
I was about to do an oil change on my 11 Q5 2.0T but ran into a bit of an issue. After I took off the plastic panel under the car, I noticed a minor oil leak coming from the passenger side of the block:
What is this leaking area? Is it possibly missing a gasket/seal? over torque? How difficult is it to sort out?
Is that on the turbo? Oil feed line and coolant line. Could be just bad O-rings. Oil line is easy but coolant line can drain out and you will need to top off your coolant. You will need a triple square socket.
This oil leak is on the passenger side block. I check higher in the block and it seems this is where it's leaking from.
forced2induce
25
07-27-2006 05:04 AM
