PLEASE READ - Oil Consumption - Necessary Steps
#381
No sorry that doesn't make any sense.If you're leaking transmission fluid that has nothing to do with the engine.They're separate entities.Hi compression in the engine ( we all wish) has zero relationship with a tranny leak - sorry eh !
#382
They are talking about the rear crankshaft seal, not a transmission seal. You have to pull the trans to replace the seal.
#383
The only way new rings would do this is if the cylinder walls were so worn that the new rings didn't seat quickly and allowed even more combustion pressure to blow by. It would only require a very short time to blow a seal.
#384
I picked up on this statement about a dealer diagnosis:
"The bad news is that when it came back after a week the transmission is leaking. The service advisor says he has never seen such a complication"
and apparently I mistakenly applied this to suggestion that the rear main seal was blowing out.
#385
With that said, while our A4 was in for one of the stages of the oil consumption problem we had the transmission fluid changed and they cracked the fitting that the filter attached to and we leaked transmission fluid pretty badly until they somewhat took responsibility and repair at no charge.
With the long list of Audi problems, I am starting to see a common response from Service Reps, "We have never seen that before". When we brought our Q5 in for burning oil, they said the same thing and I was like really because you just replaced the rings on our A4 a little over a year ago. Then my wife's A3 TDI had glitter in the fuel filter housing and I mentioned the well documented fuel pump problem and again "We have never seen that before". It must be a scripted blanket response.
Back on topic here, our 2012 Q5 has the CAEB engine and burns maybe a quart every 10,000 miles. We had some bad readings using the electronic oil meter, and then some inconsistencies whether the car head in or back in the garage but at 50,000 miles we are well below the quart every 600 miles to get them to do anything about it.
From talking to a company in NJ that has done hundreds of these, and a few other sources, I have come to the conclusion that it is very rare for a 2012 2.0T to have the excessive oil burn. The CAEB engine modifications (piston rings & timing chain tensioner) began to be implemented in mid 2011 and had been "fixed" as of mid 2012. Luckily our Q5 (engine date May 2012) had a revised chain tensioner so I am hoping that means we have the proper rings. Time will tell.
#387
#388
Very sad indeed! For very **** poor Audi engineering!!!!! Odd that there isn't a second class action law suit started for all the 2012, 2.0T's that are failing.
#389
Yeah, they gave me the song and dance about having a dealer run a consumption test, but if they won't commit to offering a repair if confirmed doesn't make it worth the difficulty of getting to a dealer every time the oil alert appears. The closest dealer isn't that convenient. Not going to drive a half hour or more every time it dings. There's a total of four dealers in the Seattle area, and the other three are far more inconvenient than the closest. Plus, I am now in Washington DC on a year long job detail, and there's no way I would ask my wife to go to a dealer when the alert appears. She has my permission to trade it in if it continues to degrade.
