Problem with Xenon
Hello!
Anyone have any issue with the xenon or the control unit for the xenon bulbs? Since last Friday, for 4 times, my left xenon turn off (Just the beam, the DRL still on) when I'm driving and I got the warning for burning light. If I turn the car off, and tun on it light up again! I see on vag-com an I have this error on 9 - Central Electrics: 00978 - Lamp for Low Beam; Left (M29) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 158 Reset counter: 9 Mileage: 80672 km Time Indication: 0 Date: 2012.11.02 Time: 20:26:00 I Think could be the control unit on the left headlight... I this continue, I will trade the booth control units to see if the problem remain, and goes to the right side. BTW, Anyone can explain me these: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 158 Reset counter: 9 The reset counter is the number of times that this occurs???? |
Here you have the answer:
http://wiki.ross-tech.com/wiki/index.php/00978 |
Originally Posted by spijun
(Post 24368275)
About the meaning of the Fault Priority, Fault Frequency and Reset counter, I found it at: http://www.ross-tech.com/vcds/tour/dtc_screen.html
Most likely the xenon bulb is bad. You can swap left and right bulbs and re check.
Originally Posted by oaktreelimb
(Post 24368413)
When I got some time I will swap the control units and see how it works, if the problem persist and goes to the other headlight... |
