Q5 2010, 3.2L, steering wheel shuddering
Old 09-19-2018, 09:31 AM
Rami Gech's Avatar
Default Q5 2010, 3.2L, steering wheel shuddering
Hi,
I am facing this issue in my 2010 Q5, 3.2L,
In complete stop when turning the steering wheel to the left i feel a huge shuddering in the steering wheel and the left front tire also
i have noticed through my research online that the replacement of the power steering hose can solve this problem
any advise??!!
thanks in advance
Old 09-23-2018, 08:26 AM
gronk's Avatar
Originally Posted by Rami Gech
Hi,
any advise??!!
thanks in advance
There was a TSB that covered this issue that replaced the hose. Note that after I had it done, I still got the vibration and learned to live with it. It tends to be less noticeable if the power steering fluid is topped off.
Old 09-23-2018, 08:40 AM
apoelistas's Avatar
I replaced the hose on my Q5 2.0T 2009 with the newest revision (2017 at the time). Note for Q5 they never issued a TSB or a TPI. It was only offered on other B8 family but not for Q5 as far as I know. The concept however is the same and should apply to Q5s too even though not directly.
Yes there was some shuddering at the beginning after replacing with the newest part, but of a lesser magnitude, which eventually diminished to zero. Not sure if it was the stop leak SW fluid I added that helped.
Old 09-23-2018, 04:12 PM
uncleiggy's Avatar
Do you remember the part number for this hose? I also have this problem and would like to try fix it. Thanks!
Old 09-23-2018, 09:13 PM
apoelistas's Avatar
The part is called Expansion hose from vane pump to steering gear but this part is different for 1N1 (power steering) 1N3 (servotronic) and 1N7 (dynamic steering) (check which type you have)
For PR-1N3 which was mine (this is servotronic, best technology ever, you can thus retrofit Audi Drive Select) Part no depends if your Q5 is LHD or RHD
LHD: 8R1 422 893 AD.
RHD: 8R2 422 893 AD.
Old 09-24-2018, 12:29 AM
uncleiggy's Avatar
For PR-1N3 which was mine (this is servotronic, best technology ever, you can thus retrofit Audi Drive Select) Part no depends if you are LHD or RHD
1N3 for me, LHD. How hard/expensive would retrofitting ADS be? Thanks.
Old 09-24-2018, 01:21 AM
apoelistas's Avatar
Not hard and not very expensive. I purchased the full kit which came with german instructions. (Cut and paste to Google translate)
itiongo
Q7 MKII Discussion
9
04-30-2017 11:52 AM
Rons01a4
10-13-2005 02:10 PM
AudiRule
05-11-2003 02:34 PM
tranbert
11-25-2001 09:13 PM
adambalgach
Misc. Models Discussion
05-09-2001 04:41 PM
Quick Reply: Q5 2010, 3.2L, steering wheel shuddering
