Q5 4 spoke MFL to 3 Spoke Steering Wheel with paddles retrofit
#21
Next retrofit will be upgrading MFSW to facelift with paddles 4 spoke.
Looking forward to this. Materials ordered. Will give part numbers after retrofit.
Out of my head:
4L0419091AD
8R0880201L
Harness ends with J
Hope there is compatibility.
Cost is higher than first retrofit.
Photos after I receive parts. Will swap squib too due to angle sensor faults every 3 months.
Total cost 450 euros.
Looks like @DennisMitchell steering wheel but black.
Out of my head:
4L0419091AD
8R0880201L
Harness ends with J
#22
disaapointed with seller. Airbag was not dispatched due to being hazzard item (explosive). Refunded. Got vengence with negative feedback. Need more time for this retrofit.
#24
If I remember well only airbag from A4 A5 have same harness i.e. airbag part 8k0880201AC.
The steering wheel from Q7 looks the same apart from an extra button. Probably it is compatible but airbag and harness are different.
Most say that my Q5 steering wheel is compatible with Q7 too so the reciprocal holds true too. I believe 4l....ah is compatible. Ask seller just to get a confirmation.
#25
Steering wheel looks better than prefacelift, I believe. What do you think??
#27
Out of memory, with a question mark because not in parts diagram these may also be used but as I said not 100% sure. Maybe someone else can confirm.
Q7 parts diagram: 4L0419091AH
A4 and A5 parts diagram: 8K0419091AC
#28
#29
My airbag has a graphite sticker. Looks not a lot different but worth showing what I will be replacing the new steering wheel with, well not yet. The airbag order was cancelled. Not prepared to pay more than xxx so I have to wait until I get a better deal
The additional benefit will be nav button. Might be slowly moving to an android touchscreen' or mmi3g retrofit' or something in between
@DennisMitchell steering wheel looks amazing with the airbag not that ours is bad' but has an additional steering wheel button which will be useful in the far future. I would not have done it only for the looks.
#30
(After retrofitting android touchscreen)
PS. Actually if you activate coding for Bluetooth button and pressing button for 2 seconds it starts the navigation app.
No need to purchase a facelift steering wheel unless it is for cosmetic reasons or you are retrofitting mmi3g.
I will take my chances to complete the steering wheel airbag retrofit from facelift only for cosmetic reasons since the pause on this retrofit lasted long. Total cost was reduced to 370 euros (from 450).
mostly do it in order to convert slowly my Q5 to facelift internally.
(Airbag on off light and switch, Radio Concert from facelift, and the steering wheel from facelift, For HVAC will investigate the use of the silver ***** if I find out how to remove).
