Q5 Trailor Hitch - Installed and it looks great!
Old 05-26-2014, 05:21 AM
  #161
spijun's Avatar
Originally Posted by DrV
Hello Poncherelly!
I'm in need of some help. Would you still have the Word document mentioned in the post below?
Somehow I lost it and I need the info to re-code my Q5 to be able to use my trailer.
Much thanks,
Cheers!
Renier
Try this, just for MY2009-2012. For MY2013-2014 is changed the coding for ABS controller
[01 - Engine]
[Coding - 07]->[Long Coding Helper]->Byte 6, Bit 3 Changed from 0 to 1 (check box "Trailer Installed" in VCDS)
[03 - ABS Brakes]
[Security Access - 16] (Enter code presented by program)
[Coding - 07]->[Long Coding Helper]->Byte 1, Bit 7 Changed from 0 to 1 (check box "Trailer Hitch Installed" in VCDS)
[09 - Central Elec]
[Coding - 07]->[Long Coding Helper]->Byte 18, Bit 5 Changed from 0 to 1 (check box "Trailer Hitch Installed" in VCDS)
[10 - Park / Steer Assist]
[Coding - 07]->[Long Coding Helper]->Byte 0, Bits 0-3 Changed from 0000 to 0001 [Trailer Hitch Not Installed to Trailer Hitch Installed (Manually Removable) pull-down list in VCDS]
[19 - CAN Gateway]->[Installation List]-> check box 69 - Trailer
If someone needs PDF: Instructions for Q5 trailer hitch
http://autopartspeople.com/audi/inst...er%20hitch.pdf
Old 05-27-2014, 08:32 AM
  #162
Poncherelly's Avatar
Originally Posted by CrustyNoodle
Hey DrV, PM me your email address and I'll send it to you.
Email sent with file.
I changed the url at home ... I changed thecarpentiers.homelinux.com to thecarpentiers.ca. I went back and corrected the original url.
xkahn
02-08-2018 10:43 AM
LuxuryAutoKSA
A4 (B8 Platform) Discussion
09-14-2015 04:33 PM
LuxuryAutoKSA
S4 (B8 Platform) Discussion
09-14-2015 04:32 PM
xkahn
New Member Welcome Area
09-05-2015 06:20 PM
audijim113
09-03-2015 01:22 PM
Quick Reply: Q5 Trailor Hitch - Installed and it looks great!
