Rattle during start up
Old 02-19-2018, 02:47 PM
kup125's Avatar
Default Rattle during start up
Hey guys,
I'm back with another question. Whenever I start the SQ5 after it has been sitting for a long time I can hear what seems to be a rattle coming from the engine. Ive looked around it now a few times and its not a heat shield or guard loose. This only happens when the car is all the way cold and only lasts a few seconds then its gone. Any thoughts or ideas befora a trip to the dealers? thanks
Old 02-19-2018, 02:53 PM
kup125's Avatar
My first thought is a cam chain tensioner but I haven"t seen this problem with the 3.0L supercharged motor ....
Old 02-20-2018, 06:14 AM
tisi_03's Avatar
Default Start up noise
Could it be the oil pressure building up to normal? I've had this on a few vehicles that don't have a spin on filter with a check valve.
Old 02-20-2018, 01:51 PM
MurrayA4's Avatar
Any idea what oil - brand/grade you're using ? Could be a factor.
Old 02-20-2018, 03:38 PM
SJGQ5's Avatar
Is there a hum too? If so, check and see if you have a U2 CD in the player..
Old 02-20-2018, 03:48 PM
IntheQ5's Avatar
on my SQ5 it happens every morning. Less than 2 sec of cam chain rattles. After that its all good. Usually i would have fix it myself by now, but damn thing,its facing the rear. Doing it blind.
Old 02-20-2018, 05:11 PM
kup125's Avatar
Not sure just bought it from a dealer last month.
Old 02-20-2018, 05:12 PM
kup125's Avatar
Great to know it"s not just mine. Is this something normal on these?
Old 02-20-2018, 08:55 PM
Bob Petruska's Avatar
Old 02-20-2018, 09:29 PM
IntheQ5's Avatar
Normal, no. The chain tensioner has been revised. Old one was losing oil or oil was leaking back out when engine has not been operating for a while ( in our case overnight). Once engine cranks, oil pressure is build back up in the tensioner again. That 2 second is chain slapping. I use 0w-40 oil and it only makes the rattle in winter. Summer time I guess the oil Flows better or thinner and hits the tensioner quickly that it doesn’t make the noise.
Quick Reply: Rattle during start up
