Sport mode with 2.0T?
It sure does. When you shift into Drive, if you pull the lever down (instead of the right for manual mode) you will see the D turn to S on your little info display in the cluster.
Great, that is what I was hoping. Wouldn't sport mode help when climbing a grade (to reduce gear hunting)?
All it does is keep you in gear longer before upshifting. When you are WOT in D, it shifts well before you hit redline. When you need to climb a hill your Q5 will downshift no matter if you're in D or S if you're already in a high gear.
