SQ5 custom courtesy door lights
I couldnt find these anywhere so had some specially manufacturered.These are not off the shelf items and you cannot buy these anywhere else in the UK or abroad.
You can even rotate the projection so it can sit across the door entrance or in line with the door itself.
OK tnx. that is an expensive way to do it
why not like the old slide projectors. they could even done it like professional slides, where the image was sandwiched between two pieces of glass so that it would remain flat even with hot air from the bulb. not a case here with LED
