SQ5 custom courtesy door lights
Old 04-28-2016, 10:29 PM
Chaznik's Avatar
Default SQ5 custom courtesy door lights
I couldnt find these anywhere so had some specially manufacturered.These are not off the shelf items and you cannot buy these anywhere else in the UK or abroad.
You can even rotate the projection so it can sit across the door entrance or in line with the door itself.
Old 04-29-2016, 06:30 AM
waninae39's Avatar
can we make a custom image. it is as easy as replacing the sheet of film with your own design?
Old 04-29-2016, 06:41 AM
Chaznik's Avatar
They are not a basic film insert.
They image is built into a small projection unit.
Old 04-29-2016, 09:47 AM
waninae39's Avatar
can you please elaborate. is it a JPEG type of file and it a has a small CPU that runs a small projector system?
Old 04-29-2016, 09:51 AM
Chaznik's Avatar
It is an image printed onto a lens which is then built into a projection tube lit by an LED.
Old 04-29-2016, 09:54 AM
waninae39's Avatar
OK tnx. that is an expensive way to do it
why not like the old slide projectors. they could even done it like professional slides, where the image was sandwiched between two pieces of glass so that it would remain flat even with hot air from the bulb. not a case here with LED
Old 04-29-2016, 10:00 AM
Chaznik's Avatar
You run the risk of damp ingress and discolouration
Old 05-02-2016, 07:43 AM
NorthValley's Avatar
So are you selling them?
Old 05-02-2016, 08:42 AM
Chaznik's Avatar
Sure am
https://www.audiworld.com/forums/parts-sale-201/audi-sq5-puddle-door-courtesy-led-projector-canbus-error-free-lights-x-4-a-2899744/
Old 05-02-2016, 07:14 PM
alpinestaraudi's Avatar
These are all over ebay / amazon and have been for some time. I'd rather buy from them personally then some guy reselling them for a profit. gl tho
Quick Reply: SQ5 custom courtesy door lights
