TDI or 3.0T for towing?
#11
Regarding braking, use of engine brake can help a lot. I changed my steering wheel so that I had the paddle shifters. I use them for deceleration. The transmission goes back into D when you get down to a stop. You can also slide over the shifter to manual and take control of the downshifts to use engine braking.
#12
Ok merton let's highjack your thread and talk about the joys of the 2.5L Busso in the Gtv6.Mine's not my daily but I often take her on extended trips to northern Quebec on business.2k miles no problem she sings a sweet song.For towing not so much.But really if you want the best Audi vehicle ever sold in N.A.with excellent towing abilty go for the Tdi.point finale.
Anyway, if I can find a TDI with B&O for a price that isn't insane , we'll get it. I'd still appreciate any comments regarding other desirable options that the Prestige has over the Premium Plus. Thanks.
#13
merton when I chose my Tdi -14 I sat in both with and without B&O put on some Stones and AC/DC and honestly I can't say the upgrade is worthwhile.I went with base system and I'm perfectly happy.Far more important is to have the MMI 3G setup which has the jukebox and Bluetooth audio streaming. couldn't ask for more but that's a very subjective opinion.Even the sub-woofer, an often maligned item, is great when listening to Led Zep.the Who, April Wine (plug for Canadian music) etc.As you can tell I like folk music !
#14
Thanks, Murray. Connectivity is important to me, but I much prefer a direct USB connection over Bluetooth & at least my mind believes I can still hear subtle audio differences. Definitely no MP3's for me. I stream internet radio (alt-country, rock, bluegrass, & folk), so a good interface is important. Sirius/XM sounds like broken glass to me. So the MMI is on the requirement list.
Did the Q5 have an option for magnetic suspension damping? I've enjoyed having that on my 535.
I work on a Nashville-based country music tour. We had shows in Calgary, Saskatoon & Winnipeg last weekend. Brett Kissel is from Alberta & has opened for us on previous tours. He came to see us in Winnipeg. I'm not a huge fan of commercial country music but he does some great stuff. I've seen him perform in a bar on either PEI or Nova Scotia (Sydney?) can't call up old tour dates now- but there is some great music coming out of your country.
Jim
Jim
#15
#16
I thought engine braking has to do with engine compression with little or no detonation of air/fuel mixture.
#17
This is all done because gas engines rely on air for the engine throttle. diesels rely on fuel.
#18
Dennis I come down on your side on this one.Diesel downshift "compression" because that's what it is, is produced by the pistons trying to compress air at a high ratio (17:1 on ours.) There is absolutely no doubt that compression braking on a diesel is vastly more effective than on a gasser.
I'm glad by the way, that diesels do in fact produce vacuum.Otherwise my braking foot might get a little tired.Ah well I guess I could always convert to hydroboost ! Sorry can't help myself.
#19
I would like to flush this engine braking discussion out some more. I looked up on wikipedia "engine braking". https://en.wikipedia.org/wiki/Engine_braking
The wiki author states much what Coolieman stated in his post. The wiki goes further to state that the diesel engine compression stroke is offset by the decompressing "power" stroke.
But in a diesel engine engine braking scenario, there are other systems that provide "braking". The TDI turbocharger, the EGR, and the DPF.
So I suspect these 3 systems are providing the "engine braking" that I see when take my foot off the accelerator and employ paddle downshifting. Granted, I see much stronger engine braking with my S3 with its gas powered 2.0L and dual clutch transmission downshifts, but the braking with the TDI is very useful.
#20
It's more work for an engine under vacuum to try and pull air behind a shut throttle body than it is for an engine with a 10:1 or 16:1 compression ratio to compress air.
Air compressed will always want to uncompress. Just looking at the 4 strokes of an engine with no fuel/spark/detonation.
Stroke 1 - Sucking air into the cylinder. Much easier to do in a diesel without a throttle valve. A gas engine will struggle to suck this air in.
Stroke 2 - Compression, the diesel engine will struggle here because the CR is much higher than a gas engine.
Stroke 3 - Detonation - this step does not happen because there is no fuel or spark. Air that is compressed at a higher ratio (diesel) will want to expand more rapidly once uncompressed (think entropy). This pushes the piston back down. Compressed air does have energy.
Stroke 4 - Exhaust valve opens and air leaves. Gas engines make all these crackling popping noises because they are chocked of air. If there is minimal air in, there can't be more air out. This is why diesel engines have exhaust valves (Jake brake) to hold the air in the exhaust. now the exhaust has nowhere to go and creates negative horsepower.
My whole point is that gas engines provide better engine braking than diesels.
