ThunderDent Q5 (Ibis/Cinny) OEM+ **build thread**
#132
*Quote from 034's site*
Oxygen Sensor Spacer - This spaces out the secondary (rear) O2 sensor to remove MIL or CEL issues caused by removing the factory catalytic converter. Professionally manufactured from stainless steel, not cobbled together by hand like some other products on the market. Spacer will add approximately 1.7" to the height of the sensor. 034Motorsport oxygen sensor spacers feature a flare seal seat, so no sealing washer or gasket is required.
http://www.034motorsport.com/engine-...i-p-19952.html
#133
There are a lot of options on eBay, but I found these to be the best, which is why I purchased them:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=300933592534
Note: The false pedal/footrest still requires drilling if you choose to use it.
Thunder, I spent the afternoon reading through yours and Birdman's build threads here and on AW. Thank you for allowing me to live vicariously through you. I'd never do all these mods to my Q, so instead I just look at your pics and drool.
#134
I'm getting ready to order the S line rear bumper setup, and I was curious as to if the two plastic pieces in the upper right hand corner of the below picture were the "guides". Do you know their purpose?
Also, in regards to the rear fender liners, what is the difference between the factory non S liners and the set you had to purchase? I've seen people reference a gap, but where does the gap remain if you used the stock liners?
Thanks for your help!
askered
Q7 MK 1 Discussion
06-22-2013 05:46 AM
Imola Ghost
Telematics Discussion
12-14-2008 02:42 AM
