Tow hitch on Q5
#11
I just purchased a 2013 and had the tow hitch installed. It did not come with a wiring harness to connect to a trailer. Where do I source the wiring that plugs into the outlet by the hitch?
Thanks,
Scott
Thanks,
Scott
#12
The bumper is not cut at the port; a section pops out. If, and that's a big if, you get it done at a dealer. Aftermarket, your guess is as good as mine. I had one added just for a bike rack. The rack on top, with my steep driveway, just wasn't feasible.
#13
The wiring harness on a Q5 does a lot more than just control the lights on the trailer. I believe it will also adjust things like the engine management system and ABS. If you are adverse to taking it to the dealer, you should find an independent with experience in this area.
#14
All hitches should be centered on the car. If not, you towing experience will be 'interesting' at best.
What makes it look offset is the plug for the trailer's electronics. They need to make a cut on the left side of the receiver.
I guess they could have been more creative and just cut a small hole for the plug, instead of just widening the main cut out.
I wonder if one can ask for the whole bottom plate to be dropped instead of leaving it to chance.
Also, my dealer insists that the install is from the factory not the port. Is this the case now?
RR
12
04-20-2000 06:49 PM
