Tranny
Romaroe, I experienced a transmission failure at 200 miles. I was really regretting my purchase. However, I received an identical Q5 a month later - I now have 5,000 miles on it and I've been very happy with the vehicle. I'm not sure what is causing the early transmission issues and hopefully Audi figures it out and acknowledges there is a known issue. I know how frustrating it can be - I recommend you contact Audi USA and inquire about a replacement vehicle rather than simply having yours repaired. Good luck.
Perhaps it's semantics, but I disagree. The end consumer is purchasing a product from Audi, therefore, it is an Audi issue. Regardless of whether Audi manufactures the transmissions or not, they are accountable for ensuring their supplier delivers a quality product.
It's absolutely Audi's responsibility, no doubt. Not speaking to stash64's intent, but IMO mention of the 8-speed tranny being a common piece of hardware shared by many makes (Audi, BMW, Bentley, RR, Jaguar, Chrysler, Jeep, etc) is relevant, no?
That sucks but it's a mechanical product and these things do happen. So long as Audi straighten out the problem for you then all will be well and you can enjoy the car you obviously love because you chose it.
My point was not to suggest it is not Audi's responsibility, but that this particular failure is not indicative of Audi quality because it could have happened with any number of different car manufacturers given that it is a common transmission. I think it is ZF... someone correct me if I am wrong.
so if the tires on your car turned out to be defective, is it still an audi problem? yes, audi should take care of the issue, but i'd hardly chalk it up to bad engineering by audi.
I have to go with the view that this IS Audi's problem. Its their name on the car and most people will have no idea (and wont care) that ZF built the transmission. Further, we dont have any data as to the failure mode of this particular transmission... could Audi have misfilled it with Mazola instead of tranny fluid (tongue in cheek) leading to failure? That would certainly not be ZF's problem. Ultimately root cause is likely to be ZF's but the buck stops with Audi. Any good company will not try to pass the buck and will own up to something like this while concurrently choking the crud out of their supplier for putting them in this position. This is certainly the way it works where I work. If the customer has a problem with our product it is ALWAYS our fault when speaking to the customer.
