Used Audi Q5 What to look for
#21
Well thanks everyone but.. I own it now! LOL! I did it today. Found out some service records on it till I tracked down the dealership where it was purchased new. The lady there said I couldn't get records unless I owned the vehicle. I did look at the carfax and saw that they did an oil consumption test then 7xx miles later the vehicle was serviced. Hoping it was pistons replaced and it was too much to list in detail. Guess I'll find out tomorrow when I call her back and get the service records. Wish me luck!
#22
When I owned a garage there was a definite, close to majority, group of my customers who would come in and ask for my advice on what to buy and then announce that they'd just bought such and such, often one of the ones I had warned against.Oh well what can you do ?
#23
Check if you have the newer PCV or post a photo with its part no. If it is dual colour white and black you have the newer engine firmware which minimizes the oil consumption issue. If you dont you are in serious trouble.
Then ask dealer to give you your cars piston/piston rings conrods part numbers and post this information here.
Will let you know if you got lucky.
#24
Yeah, yeah, I know! LOL! I watched videos on the chain/tensioner issues and that would be cake to fix. Piston/rings isn't even beyond me to do so I just need to find out if it's been done. My buddy was behind me after work Friday and said it was huffing black smoke when I took off a couple times. Seemed to be fuel rich issue. Also stalled on me when I tried to take off after making a stop yesterday for about 45 minutes. Stumbled a few times at take off after that and has seemed fine since. Will check out the PCV a little later. My buddy is detailing it right now. Will look better for resale/ trade in purposes right?
#26
I already priced all the parts to do the piston change too. $700 ish for everything they give their techs to do it including oil change, coolant, all seals & gaskets etc.
#27
You can not bore and hone the block as Audi doesn't supply over sized pistons and rings.
Plus there is a "special cylinder wall coating" that CAN NOT be honed when new pistons and rings are installed. When the Audi dealer installs pistons and rings under the less than 80K miles warranty there is still some of the remaining factory cylinder wall cross hatch honing pattern there to break in the rings properly. If the cross hatching is gone you will never break in new rings and have a tremendous oil burner.
No cylinder cross hatching also means a block replacement.
Black smoke and stumbling could mean a lot of things. Your high mileage engine could have excessive carbon build up.
#29
Well, I ran the bore scope into all the cylinders and the cross hatch looks good. PCV looks to be all black though. Maybe I should run it up to the dealer and see what they say it needs and go from there. Is the newer firmware an update they can do or does that include the new pistons and rings?
#30
You better check your cylinder walls though the sparkplug holes with a borescope first. The factory rings have a tendency to break and score the cylinder walls. Any cylinder wall scoring requires a block replacement
