Wire Harness with missing plug
Good day
I recently bought a 2016 Audi Q5 2.0L with 8000km. It was a write off, and I have just about got everything back in order.
I am stumped though by three wires that come from the same harness that the driver side engine mount sensor is on.
The plug has been sheared off
The wire colors are Yellow, Brown with green stripe, and Grey with yellow stripe.
These are very light gauge wires so I assume it is a sensor of some sort.
Any assistance in locating the sensor it is supposed to plug into, and a plug part number would be very helpful.
Thank guys.
Alex Loncaric
Thank guys.
Alex Loncaric
Yes that all makes sense it must be the G31 sensor.
I did have a plug in the area, and it went on but it did not seem correct as the sensor has an alignment key and the plug did not.
Now I have to figure out where that plug should go.
If you remove the senor it should also have the same corresponding terminal number molded/indicated on the part.
I don't have the latest ETKA with 2016 P/N's. Contact Spijun here on this forum and he can help you with the P/N.
Thanks, I did not see the terminal numbers the first time.
And to help any body in the future the plug part number is 8K0 973 704 A
Now I just have to find where the wrong plug I had initially used goes, thankfully if I remember correctly it was pretty short, so it should all work out.
Thanks again
Thanks again
Fastscirocco
Audi Original "S" Cars
9
02-23-2008 11:26 AM
Mitaka
08-19-2005 12:50 PM
Ken 4000
08-11-2001 10:13 AM
