Anyone else think the 2.0TFSI sounds like a tractor engine? - AudiWorld Forums
Go Back  AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 /Q8 > Audi Q5 > Q5/SQ5 MKII Discussion
Reload this Page >
Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
Sponsored By:
Sponsored By:
Old 04-12-2018, 09:34 PM
Default Anyone else think the 2.0TFSI sounds like a tractor engine?
I have the 2.0TFSI, and whenever I climb hills, or accelerate at a medium pace from a stop, the car sounds like a tractor engine, very loud buzzing noise, can hear each individual cylinder struggling,
Something wrong with my car?
2018 2.0TFSI
soguy12 is offline
Old 04-13-2018, 05:07 PM
That is the by-product of a 2.0 L engine. (unfortunately).
Wires is offline
Old 04-14-2018, 05:45 AM
I haven't noticed that myself. Prestige with the acoustic glass though maybe that's blocking it.
umdstu is offline
Old 04-14-2018, 06:42 AM
2018_SQ5's Avatar
Mine sounds freaking awesome... oh yea it's the 3.0 L turbo
2018_SQ5 is offline
Old 04-14-2018, 07:05 AM
Smaller displacement / number cylinder engines need to rev higher to get power, and have less cylinders to smooth out the ripples in power.
The Audi 3.0 is insanely smooth for a 6-cylinder (smoother/quieter than any vehicle I've owned). When we test drove the Q5 with the 2.0, you do hear it work harder.
Wires is offline
Old 04-14-2018, 09:49 AM
Are you talking about at low RPM? Are you in "D" mode in the transmission? If so, try shifting into "S" mode and see if your complaint about the sound goes away. It will usually choose a lower gear and keep the RPMs up a bit more in this mode.
Current Audis in "D" shift mode will definitely load up the 2.0T engine at much lower RPMs than I would have chosen with a manual transmission. There is torque down there due to the turbo, but the sound reminds me of what I would call "lugging" and I would normally choose a lower gear to avoid that. But, I am getting used to it, and aside from this worry about lugging I think it's a worthwhile trade-off for the overall quieter drive and the better fuel economy.
I just hope the knock sensors and engine management are smart enough not to be causing any damage from these low RPM grunting sessions.
carkarl is offline
Old 04-14-2018, 12:04 PM
It's basically "impossible" to harm the engine in these vehicles under conditions like you are describing. It will downshift, open the wastegate to dump boost, close the throttle, add more fuel, etc to ensure the engine doesn't exceed any operating conditions.
The 3.0 feels like similar at lower RPM's, but its more of a lazy throttle mapping (you need to press harder on the petal to make it do anything) for fuel economy than actual "lugging" the engine. If it was lugging, it would downshift for you. When you drive in S, the mapping is a lot more responsive to the petal than D so it just feels more perky. If you prefer to drive in D, you can buy those petal boxes that changes the curve of the throttle so you can get that S type response from the petal running in D.
Wires is offline
Old 04-14-2018, 03:44 PM
No
Badger56 is offline
Old 04-15-2018, 07:11 AM
mine sounds like a tractor with flapping sound during cold start each time, particularly loud but goes off just after the engine rev below 1K. not sure why but its a daily ritual!
Audigy76 is offline
Old 04-15-2018, 12:24 PM
When the engine first starts, the waste gate opens to shunt air around the turbo, so you are hearing the actual engine output (not muffled through the turbo), After ~30 seconds, the waste gate closes, and the sound diminishes.
Wires is offline
Quick Reply: Anyone else think the 2.0TFSI sounds like a tractor engine?
