Audi Drive Select Suspension
Hi Guys,
I recently bought a Prestige Q5 without adaptative suspension. I seriously notice the suspension is softer when I switch to comfort mode but I don't like the engine in comfort mode. So I switch to individual mode to customize for the ride and I don't see any option for suspension (only Engine/transmission, steering wheel and ACC). I read other post and owner manual which said that only car with adaptative suspension can adjust suspension. My question is does my suspension becomes softer or I'm just being hallucinated? If the suspension is really softer, where is it in the drive mode?
Thanks
Thanks
You are hallucinating. Suspension is fixed, unless you have adaptive suspension. If the suspension is not listed in the MMI where you can adjust the individual mode, then your suspension is fixed.
Yes, I noted when I first received my car that mine has the same. I asked a knowledgeable guy in Audi Customer Service UK and he said, "certain plugs and circuitry (not all) are included just in case the full adaptive suspension is fitted down the line.
It would cost more to change the assembly line process for every different configuration they build.
Yes that is what I was eluding to, but did not phrase it well.
Yea I guess it's why auto high beams can be turned on if not purchased new. My last car had the wire loom for fog lights even if not installed. Made adding aftermarket ones a breeze
Do you mean High Beam Assist (HBA)? If that is what you mean, that is the biggest con by Audi to make more money. It just a matter of coding. I had front and rear parking cameras fitted the other day and the guy enabled HBA for me in 2 minutes. I think Audi charged £150 at the time my car was produced. Perhaps now free depending on the country purchased in.
Luxus Panzer
10-05-2021 07:02 PM
gliTTch
04-27-2004 01:35 AM
Innovator
07-13-2001 05:48 AM
