Battery location FY Q5 - that is model year 2018 on
#11
The charging system adapts the charging current over the life of the battery. A new (fresh) battery can be charged at different rates than an old tired one. In the "old days" the alternator just perpetually charged the battery, and nobody cared. For efficiency reasons, the alternator doesn't drag down the engine all the time (IE better mileage), and is cycled during times when charging is required.
Because of this, the car needs to know when a new battery is put in, or it won't last since it's not getting the proper charge profile.
#14
You just don't get the same life out of the replacement. How much, I cannot comment. IE 3 years vs 8 years? 7 vs 8?
#15
Yeah, it's more complicated than BMW. There you just click on adaptations and new battery, done.
People have just put in new batteries and not coded them with BMW's and nothing "bad" has happened but the alternator will overcharge as stated above. The biggest key was to make sure the reserve capacity and AH were the same and not go cheap on the battery. The alternator is relying on the fact that the battery is the same size and type (AGM/lead acid) to charge it at the optimal rate.
Pulled randomly from youtube.
#17
Yes, they shouldn't have a problem. My 2008 3-series BMW had to be registered as well, so it's been around for a while (at least in the German brands).
#18
+1 for the 08 E90
I used the Foxwell/Schwaben scanner and will do so again.
#20
