Carly OBDII coding
SQ5 Down Under
Carly OBDII coding
I had been using Carly on my BMW in the past with good experience so I'm curious to see if anyone use Carly for VAG for their Audi? Originally, I thought the carly OBDII BMW adapter will work on my Audi but it doesn't so I need to buy another Carly VAG adaptor. So before I pull the trigger, could anyone give any feedback on carly VAG?
I know most of u use OBD11 but Im an IOS user and OBD11 doesnt support IOS last time i check. Pls correct me if im wrong.
Doing some cost comparision, Carly adaptor + full verison (all access) is around the same as OBD11 adapter but some function require buying credit for OBD11 which will ultimately cost more than Carly?
OBD11 is in alpha testing an iOS version of the app, but it will require a new dongle - the current version will not support iOS.
https://m.facebook.com/story.php?sto...go.com%2F&_rdr
SQ5 Down Under
Audizine users report being able to run OBDEleven on IOS using an emulator, so that shouldn't stop you. I haven't found any changes made by apps which adaptations or long coding can't also do. Apps are just a convenience. You can also get free credits - 1 free per day for starting the app and up to 4 more (albeit in an annoying fashion - by letting video ads run on your phone for 30 sec).
As suspected, I didnt think there will be much ppl using carly app when OBD11 has been around longer. Carly is still quite new in VAG.
Video motion
I have a Audi sq5 2018 and I have Carly the obd2 and I’ve activated video motion by the Carly obd2 app and it says active but on the car it’s not working when I drive off the message pops back up
dool
11-03-2005 08:27 PM
