Codes P01412 and P0604 - what are they?
My JB4 read these and they are there even after deleting codes - any idea what these are/why they show up? Google says one is a memory problem, other is inconsistent across the web - but if it’s the same as a BMW, could be a vacuum or air pump leak? Any idea?
FWIW, no problems with the car at all, no CEL, runs fine.
Similarly, I had a P0100 lately. Have you sent the codes to George? He mentioned there is a new app update coming which should tell the cause. Not sure how long until the update.
Previously I got
8176 - got a few times
8A4B - accompanied by Drive System error and wouldn’t clear
George said these faults relate to the plugs that connect to the first sensor. After this they replaced the harness. The P0100 is with the new harness. Fortunately no CEL with this code.
Previously I got
Previously I got
Previously I got
There is troublecodes.net that can help figure out the area to look.
p0100 is mass air flow issues maybe need a new sensor, clean the sensor, or fix wiring
p1412 is EGR Differential Pressure Sensor Signal Too Low, possibly replace sensor or clean it, check wiring, check egr system
p0604 Engine control module (ECM) -RAM error
ouch! That’s memory , could be bad or could correct itself if it got bad data, or may need reprogramming at best, new module at worst.
Check wiring and pins on ECM.
wshymas
08-26-2022 07:19 AM
Jason H
08-11-1999 06:58 AM
