Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
Goes into gear but doesn't want to move?
Old 03-26-2019, 05:51 PM
mungo513's Avatar
Default Goes into gear but doesn't want to move?
Put on some spacers this evening (5 front and 12 rear) and when I went to drive it wouldn't move. I put the car in allroad and tire change mode. Nothing different than I've done before. There are no lights, no codes, and ran a Obdeleven scan just to be safe. I can hear the parking brake close and open. I even used Obdeleven just to try opening and closing the brakes. If I give it a bunch of gas I can get it to move but I only went about a foot. Its like the brakes are closed. I had to call it a night as its now dark and cold. Will see what comes about in the morning with full light. Anyone have any thoughts?
2018 SQ5
Old 03-26-2019, 06:08 PM
Weebl's Avatar
Did you use longer bolts? Jack the car back up and see if the wheel turns.
Old 03-26-2019, 06:27 PM
mungo513's Avatar
I did but only a couple mm longer. They were ball seat but not as flat seated as the factory bolts. I was thinking they might be something so I ended up swapping out the back bolts as the last thing I did tonight. No luck but going to swap the factory bolts back in tomorrow morning. What could too long of bolts do? I would think they would just bottom out and not allow you to fully tighten/seat the wheel.
Old 03-26-2019, 06:33 PM
Weebl's Avatar
yeah bottom out..... on the hub.
Back the bolts out a few turns and I bet the wheels will spin
Old 03-26-2019, 06:37 PM
mungo513's Avatar
Thanks Kevin. I'll swap out the fronts in the morning. Appreciate the input. Thanks, Brendan
Old 03-26-2019, 06:41 PM
Weebl's Avatar
Sure thing.
::zuprong::
21
05-27-2008 12:33 PM
slowEURO
11
07-22-2007 11:01 AM
SNAFU 4
05-04-2007 04:33 AM
sabih786
10
03-24-2007 06:45 PM
sissupr
07-07-2003 07:35 AM
Quick Reply: Goes into gear but doesn't want to move?
