HomeLink® garage door opener question on 2021 Q5 progressive
I noticed that my new 2021 Q5 progressive shall supports HomeLink® garage door opener. But I didn’t find the garage opener buttons on the roof.
Does anybody have experience how to use the feature in 2021 Q5 progressive model? Thanks
The following 2 users liked this post by Greenc:
hersee (01-03-2023),
itcsburnett (03-08-2022)
I have same vehicle...and same problem, its in the MMI...you have to look for it but its there. I haven't had luck getting it to work however, and will keep trying, it suggests have to go to the opener unit and work with that. I have prem + and nav and still haven't found the temp gage. Okay for out temp but not for engine temp. Been on all the screens and no luck.
When leaving, I clipped my old-fashioned remote control on my passenger visor to use - not sure why Audi made it so complicated.
The following 3 users liked this post by GeriatricSQ5Guy:
Just swipe down and the programmed garage doors appear. There is an option to store the geo location for a door so that the "buttons" pop up automatically when you get closer to the door, works reliable for me so far.
With VC you get the oil temp which is more important and should be the decision basis for when to floor the gas pedal or not.
I also found a video for somebody who want to know how to configure it.
yeah I had issues with my condo complex’s garage system too. So I carry around the liftmaster button instead. Some people say with persistence, the homelink should sync up with liftmaster but no luck after 10-20 mins of trying
If the door is HomeLink compatible then it should work. it might be tricky though.
Over the years I accumulated about 10 different remotes, all different models, all programmed for my two garage doors and working fine. Only two of them were playing nicely with my 2021 Q5e (and my 2017 A4 before that), the other were either not waiting with the car or the car could not be synchronized with the opener. If possible try another opener.
The 2021 Q5 also has three different modes, so if the standard mode does not work, try one of the other ones.
